76 f150 4x4 np203 problems help!!!!!!!!!!!!
Old 03-28-2013, 01:23 AM
Scotty76's Avatar
Scotty76
Scotty76 is offline
My truck when in 2wd hi "or unlock 4 whatever you want to call it" it chatters hard and wants to jump into 4 lock while driving , the chattering sounds horrible! I've adjusted the linkage and no difference
And when I disconnect the linkage and shift the lever on tr case to 4 lock, it clicks in nice but pops out when in drive? , if I hold it in it stays
Not sue what to do at all, I know my shifter assy is worn out, do I do a twin stick conversion?
Also truck has np203 and also has manual locking WARN hubs, not sure if transfer case is converted to part time or if someone just put in manual hubs
Any help or direction would be appreciated, truck is driving me insane lol
Scott
Old 03-28-2013, 12:38 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
NP203's with part-time conversion kits are notorious for this...
It's usually because the shifter wasn't adjusted (or not adjusted correctly) after a part-time kit was installed and the t-case was run with the gears not fully engaged, eventually wearing down the teeth until they no longer stay in gear.
The easiest fix is a NP205
Old 03-31-2013, 02:32 PM
7Ford6's Avatar
7Ford6
7Ford6 is offline
x2 on the 205..
BossFan
01-22-2012 09:01 PM
Walroski
16
05-28-2011 09:40 PM
zaaac
22
01-12-2010 06:27 PM
'77hiboy
04-20-2008 09:43 PM
oem78
02-11-2004 12:38 AM
Quick Reply: 76 f150 4x4 np203 problems help!!!!!!!!!!!!
