2wd 2005 f150 torsion bar adjustment to lift front end
biggest tire I'd go with would be a 285-75-17. IIRC that is about a 32.5" tall tire. I am running with a 2.5" level kit up front as well. all the kit is are spacers that goes between the front shocks and the shock tower. gives it a good stance and allows that 32 to slide in there.
now I am running a 275-75-17 goodyear wrangler, was on the bfg's in my sig. the 10 mm of width saved me about 300 dollars. :P
don't forget if/when you do that spacer kit, you need to adjust your headlights...you will blind some folks at night if you don't.
edit to add, these trucks don't come with t-bars. its a coil-over-shock setup with lower control arms. similar to a strut setup.
50dann
10-22-2013 12:54 PM
Big Sanch
2004 - 2008 F150
08-11-2005 02:48 PM
