So what does this do?
So I'm getting ready to put things back together and I believe I'm a bit out of my depth. Really I've got 2 questions. The first is what is this thing with the red arrow pointing to it? It had a ton of stuff connected to it, but doesn't look like it does anything important.
The second question is about vacuum setup. With an offy intake, efi manifolds, and an edebrock carb, I'm pretty sure about a few things but others I'm a little hazy on. The intake manifold vacuum connects to the pcv vavle, but there are 2 connections, a 3/8 and a 1/4. Looks like the 1/4 should go to the pcv then do i just plug the other one? Then from there, there are 3 ports on the carb. A ported vacuum (this should get capped?), the full time vacuum port (???), and the PCV port (duh). Soooo where do I plug in the dist vacuum advance?
Well I posted a little early, nevermind about the carb vacuum questions, I just realized it came with a handy DVD that explains it. Well I feel kinda dumb now...
Still not sure what that thing is with the red arrow, and what the heck do I do with the smaller pcv port and the intake manfold ports?
Ahh thanks, it's going to stay there, but it'll just be for show (it looks pretty doesn't it...)
Anyway, so i think I've got the vacuum worked out, the manifold vacuum goes to the brakes, so here's my list:
Manifold vacuum -> power brakes
Main carb vacuum -> pcv valve
ported carb vacuum -> dist vacuum advance
Annnd that's it. For some reason I was thinking this would be more complicated.
Johnkimble
12-09-2018 10:36 AM
ErrorS
01-02-2008 06:26 AM
1Digger
05-02-2007 12:09 PM
