FICM voltage drops to 0 - at initial key on
It's been cooler here the last 2 days (45* in the AM).
I activate the SG2 when I turn the key on to watch voltages and temps.
The last 2 mornings, I turn the key on to let the GPs warm up and I notice
my Ficm Main Voltage drops from 34v to 3v in about 5 seconds, so I don't
bother to turn the key. Other volts are 11.7 to 12, including analog volt meter.
I cycle the key and FMP goes to 48v and I start instantly no issue.
During drives FMP is 48.5 to 49.5, I've never seen it waver.
So, this AM, with the FMP at 3v, I turned the key and no start.
I cycled the key once, same thing, then on the next attempt FMP went to
48v and truck started instantly...
So, is this the FICM, or a lame power relay/feed to the FICM?
I am driving from FL to NC tomorrow, so a FICM replacement from Ed
isn't gonna happen before the trip.. but Atlas 40 from Ed would be
fine with me - I just don't want to do it before needed..
Thanks
EDIT:
no engine bay work in the last few months, but it just occurred to me
we had LOTS of rain over the weekend, although I did drive in Sunday
without issue..
Thanks
EDIT:
without issue..
I never cycled my key when mine was doing that some what.
And, like you found, NOT turning the key to start until 48v. works best.
I went for months with dropping main power voltage until I could have the truck down while the FICM went to Ed.
The lowest mine got was 30v and in 10 seconds or so, reached 48v then I started.
AND, the rest of the day it remained at 48v on KOEO.
Ed repaired my FICM and it has stayed where it belongs ever since.
This situation is why I like the scangauge II over my Torque APP or an APP like DashBoss. Those 2 APPs take too long to sync with the PCM to catch those readings at first KOEO.
And it is why I always tell folks to test FICM with a second person to turn the key on. Takes longer than 10 seconds to turn the key, crawl up a step ladder and carefully put the probes on the FICM.
Need to get your FICM fixed.
I have a video of what mine was doing if you would like to see it.
Thanks for that info.
I am wanting the Atlas 40 from Ed, my off-the-line turbo lag is huge,
I just didn't want to "hope" this was the FICM vs. something external
to the FICM.
At first, I thought the SG2 was confused, hence I tried to start - once.
Don't need to buy new injectors too..
Oddly, mine FALLS from 36 or so, to 30, 24, 18, etc. until it stays about 3v
during about 5 seconds or so. I changed the SG2 to "fast refresh" a few weeks ago.
Cheers.
to the FICM.
Cheers.
When my FICM started to go it showed 48+ at all times except after my truck sat at work it would fall to 43-44 volts about 3-4inutes after starting and only held that voltage for a few seconds.
I went ahead and did the exchange program with ED, but certainly FICM's seem to do weird stuff when they go.
Josh
Josh
I thought of another test to try (appologies for getting off topic), since I wanted to be sure that the OBDII plug was hot w/o KO. I went out to the truck and didn't even take my keys. Started Torque, went to adapter Status and with one hand on the Adapter, in position but not seated, I watched the Torque Bluetooth connection to adapter. It was almost instantaneous from pushing the plug in to the status changing to "connected" on Torque. So I know at least on my truck the OBDII port is always hot.
I was pretty sure it would work that way and since watching the FICM voltage at Start Up is key, I'd be out buying a scangauge if it didn't work...
Just wanted to link to the solution in case somebody stumbles upon this in the future)
Had FICM upgraded by Ed and problem remained (but I love the atlas40)
Replaced the FICM Power Relay and it fixed this problem.
https://www.ford-trucks.com/forums/1...ng-solved.html
Yeah, I'm not sure if it's because I'm older or having a 44 gallon fuel tank and an Excursion has made $33 dollars seem cheap.
Heck, I spent $75 for a case of Mercon SP two weeks ago, and bought 2 gallons of Rotella T6 with a $5/gal rebate last week. Each time I stopped at those stores, I experienced the need for this relay! when I tried to leave.
Having FTE to work out these issues has saved me SOOOO much $$$ I can't help but be thankful to all the folks that share their knowledge on FTE.
Gonna run some tests on the old relay before I cut it open to see inside.
Didn't cut open my Oil Cooler so this is the how I can contribute..
