unsure of what engine is in my ford - Ford Truck Enthusiasts Forums
Old 03-27-2013, 01:41 AM
projectdagger's Avatar
projectdagger projectdagger is offline
projectdagger is starting off with a positive reputation.
i recently became a proud owner of a 60 2 door falcon wagon. i have been under the impression that the engine is a 144 according to the aircleaner. i had a bit of trouble finding a new pcv valve for it. in which i was told that my car should have a dump tube, instead of a pcv valve. also that the cylinder head is from a 200 because the throttle linkage does not sort of fit, causing the throttle to be stuck partly open. earlier this evening, i found online photos of the 144 and my engine does not even look close to it. so my question, is how can i tell exactly what i have.
Old 03-27-2013, 01:53 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
Post some pics of it. I believe what you may have is a 240 i believe it is. Or it may be a 260 i cant remember. Back in the.60s.and early 70s.many of.these.cars were.changed from the.stock motor.to th WV e mustang straight 6. They.were easier to find and had nearly 45hp gain so instead of.speandimg.the.money.to rebuild the.144 or the 200 they were. swapped.i hope this.helps plus the.parts are.interchangeable
Old 03-30-2013, 07:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1961/64 Falcon's came with either 144 or 170 I-6 engines. 200 I-6 introduced in Falcon's in 1965.
240 I-6 installed in 1965/74 F100/600's and 1965/71 Galaxie/LTD's, were not installed in any other Passenger Car.
In order to install a 240 in a Falcon, a HUGE hole would have to be cut in the firewall, as it's quite a bit longer than the 144/170/200 I-6's.
250 is another I-6, looks similar to 200's. Was first installed in 1969 Mustang/Fairlane/Torino/Comet.
All 144/170/200/250 I-6's have the intake manifold made as part of the cylinder head.
260 is a V8, introduced in 1962 Fairlane/Meteor, first Falcon's to come with it: 1963 1/2 Sprint hardtops and ragtops.
1961 was the first year for PCV, so no 1960 or earlier vehicle will have it.
Old 03-30-2013, 06:02 PM
75Three90's Avatar
So i was mostly right
Oil residue in intact tract from PCV OpenTrackRacer Modular V10 (6.8l) 1 03-28-2014 05:36 PM
97 f250 460 pcv valve help. rock15t 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2012 05:47 PM
3V PCV Valve? Mr Hanky Modular V10 (6.8l) 2 11-07-2010 01:35 AM
Pcv Valve 90Ford250 1987 - 1996 F150 & Larger F-Series Trucks 5 04-02-2007 12:42 AM
89 302 No PCV Valve? Jakeman711 1987 - 1996 F150 & Larger F-Series Trucks 2 08-29-2006 05:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
