looking for an oddball part for my '90 F250 - Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
Old 03-26-2013, 11:36 PM
firewood truck firewood truck is offline
firewood truck is gaining momentum as a positive member of FTE.
I'm getting ready to swap motors in my old work truck again, the last time I did it I didn't have to correct transmission spacer plate so I've been trying to find the correct one without much luck.
I have a '90 F250 w/ the 5.8 and a 5 speed manual trans. I need the metal spacer plate that goes in between the bell housing and the block, it fits in behind the flywheel. Apparently these are specific to the 5.8/manual trans because of the 164 tooth flywheel that the 5.8 uses. ( the 4.9 and 5.0 use the 157 tooth flywheel)
If anyone has one of these, I'd like to buy it from you!
Fleabay hasn't been any help, they are NLA from ford.
Old 03-27-2013, 04:37 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Jeff's Bronco Graveyard has one for $32
http://broncograveyard.com/bronco/i-...-302-351w.html
Picture shows a bell housing, Not sure why, you may want to call
This plate is listed on the same page for nearly the same price, so I imagine the other is a plate
http://broncograveyard.com/bronco/i-...tor-plate.html
Amount of teeth should make no difference, the plate is snug around the crankshaft.
The starter head gear would be where the change appears, by the number of the teeth. You can not use a manual starter on an automatic, and vice versa
Old 03-27-2013, 11:59 PM
Thanks for the link, unfortunately it shows the plate for an automatic trans. I'll give them a call and see if they have anything for me.
Old 03-28-2013, 06:00 AM
Posting Legend
The first link is for the manual trans plate, but has a picture of a bell housing.
I'm sure it's a plate, because of the price. Best to make a call.
They also have used parts, so you probably will get what you need from them.
I have used them several times in the past, and have never been disapointed
Old 03-31-2013, 11:04 AM
They confirmed what I suspected- the starter index plate , flywheel tooth count and bell housing is what locates the position of the starter. The 5.8 uses the 164 tooth flywheel so it uses a specific index plate. Looks like I'm gonna have to keep looking.
Is a 5.0L flywheel the same as a 5.8L flywheel RustyBarnard Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 08-11-2016 08:47 PM
Will a 5.0 Mustang pressure plate bolt to an older 302 flywheel? jade79 Clutch, Transmission, Differential, Axle & Transfer Case 0 07-26-2016 08:49 PM
460 swap & flywheel tooth count. Red Mercury Engine Swaps 8 09-01-2015 10:13 PM
power master start on 360 ford? william16339 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-18-2015 10:02 PM
Flywheel and Bellhousing HELP! AtlM5 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 05-17-2015 10:48 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
