Heated fuel pick-up - Ford Truck Enthusiasts Forums
Heated fuel pick-up
Old 03-26-2013, 07:28 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
Heated fuel pick-up
Are they worth it? I am having a real hard time paying over $200 for a heated fuel pick-up. Just wondering if anyone else is running one. did you buy one or make it? I know I should prolly just stop being cheap and buy one. The cost will be recouped within 75 gallons of fuel....but I just can't do it.
Diesel Rod
Old 03-27-2013, 02:03 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Definitely worth it, but also, not that hard to do DIY substitutes. Frankly, i'm partial to installing a simple, solid hotfox or WVO Designs Hotstick, rather than risk making a homemade tube-in-tank hose, that is prone to metal fatigue or other cracking issues. If you have a DIY in-tank fuel pickup that cracked, then it could seep coolant into the veg tank. That'd be a pain to clean out, and think of the damage to your injectors/IP/etc.
they aren't that expensive. I vote for buying a hotfox or WVO Designs Hotstick. I have a horizontallymounted hotfox on my jetta veg tank, and a horizontally mounted hotstick on my IDI, both work great.
Old 03-28-2013, 07:43 PM
Never heard of the Hotstick, I am gunna google it right now. thanks for the reply.
Diesel Rod
heating your shop/ garage. can diesel be used in a kerosene heater? blueeyedfordguy Garage & Workshop 27 02-17-2014 11:23 PM
Anyone here convert an IDI to run off WVO? mozzles Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-19-2013 08:25 AM
Harpoon/hutch/FRX/Fuel bowl delete in one kit SSSimon Australia Chapter 12 08-09-2012 06:38 AM
killing interior noise suggestions not involving shag carpet joelswork 1968-2013 Full Size Vans 13 08-30-2010 06:36 AM
Wife objects to diesel...can you help?? ken bromen 1999 - 2003 7.3L Power Stroke Diesel 18 05-08-2001 09:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
