2003 4.0 long start fuel pressure problems
Old 03-26-2013, 02:30 PM
Gary E's Avatar
Gary E
Gary E is offline
So it often just cranks for 15 seconds before it fires. I put the fuel pressure guage on it and you turn the key on but don't engage the starter it goes to 30 psi then back to 0 in a 2 second time frame. It then stays at zero. when you engage the starter pressure slowly goes up and it starts running while running its a consistent 60 psi.
I presume its the fuel regulator but why does it not go up to 60 psi and why does it just stop with the KOEO?
Is it reasonable to just replace the regulator? or should I be replacing the fuel pump to at the same time? I will be doing this from under the truck since there is a lot of hard mounted equiptment in the bed.
Old 03-26-2013, 02:35 PM
Gary E's Avatar
Gary E
Gary E is offline
Does this have the regulator in it? I presume its the round cylinder object perpendicular to the assembly in the middle.
Airtex E2293M Fuel Pump Module Assembly : Amazon.com : Automotive Airtex E2293M Fuel Pump Module Assembly : Amazon.com : Automotive
Old 03-30-2013, 06:05 PM
pawpaw's Avatar
pawpaw
pawpaw is online now
Seeing as how its slow to come to pressure & then won't hold pressure after the engine or pump stops, it kinda sounds like the regulator check valve is on the fritz & maybe the pump is getting weak too???? With it being 9 years old & kinda a pia to get at & change out, I'd just opt to replace the entire pump/regulator/sender assy & call it a day.
Old 04-04-2013, 05:36 AM
italstalyon's Avatar
italstalyon
italstalyon is offline
Say you guys I'm working on a 2003 4.0 and having problems with not starting but can't find out how to check fuel pressure. I have a gauge but where the heck is the shrader valve on this?
Old 06-03-2013, 02:18 PM
Gary E's Avatar
Gary E
Gary E is offline
fuel pressure port is on the back of fuel rail near the firewall, not super easy to use.
I have two 2003 4.0s that had the same problem it was one of the lines on the fuel pump assembly had pinholes in them allowing the fuel pressure to blead off and not stay steady. Probably could of just replaced the hose but went ahead and just replaced the fuel pump assemblys they start just fine now.
1320stang
08-15-2018 02:07 PM
brcwelding
04-21-2013 05:44 AM
BURNSTOUGHFORD
1997 - 2003 F150
17
03-23-2009 04:21 PM
bigred66
1978 - 1996 Big Bronco
10-05-2007 12:16 PM
only ford
02-28-2004 02:14 PM
Quick Reply: 2003 4.0 long start fuel pressure problems
