Seat Easy Entry/Exit Malfunction - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-26-2013, 03:10 PM
ptmares ptmares is offline
ptmares is starting off with a positive reputation.
So today after a quick trip out, I unlock the doors to get in the 2007 Expedition EB EL. As I am sitting in the drivers seat and put the key in the ignition and turn, the seat proceeds to return to what I thought was my seat memory position. I was wrong.
The seat went as far forward as possible. I lost my seat memory function and the easy entry/exit does not work either. I have the option selected as "on" through the easy entry setup menu. The seat controls all work accept the easy entry option. Fuses look to be okay as well.
As anyone had this similar problem, and if so what was the fix?
Thanks
Old 03-26-2013, 07:55 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
I had a similar thing happen to me. I was cleaning the Expy one day and moved the seat all the way forward and before I released the button the seat stopped and then then moved again like a fraction of an inch. Well I think it somehow resets the memory positions because mine were lost after that. Since then I've reset everything and it's been fine. I know if you move the seat all the way back it resets the "easy entry" setting to allow more travel when key is removed so maybe going forward resets everything.
Matt
Old 03-26-2013, 07:58 PM
expoman55 expoman55 is offline
expoman55 is starting off with a positive reputation.
seat entry exit malfunction
I had a similar problem with my 05 previous EB expy. What I found was that if I started the vehicle while the seat was in motion it would often find a 'new' position and sometimes remember it. So I always waited for the seat to stop before starting. Now the other side of that is I found out the battery was going bad and battery voltage was low.. Don't know if that helps but it is what it was..
Old 03-26-2013, 09:39 PM
Thanks for the info forum. I am still puzzled as to what has happened. I will have to try a few things tomorrow with the expy. I will let you know what I come up with.
I found a section in the owners manual that explains a seat reset. Although it doesn't make sense to me yet. I will read it several more times and try a reset.
Driver Seat Acting Up Superred2 2007 - 2014 Expedition & Navigator 0 04-06-2015 02:44 PM
2011 F450 In The Shop jaybread 6.7L Power Stroke Diesel 47 01-08-2012 02:07 PM
Easy Entry Feature on 2007 Eddie Bauer EL cfranc 2007 - 2014 Expedition & Navigator 1 05-24-2010 02:00 PM
Wife Needs a Grab Bar emgee 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 10-03-2005 05:29 AM
Random Auto Show notes polarbear Ford vs The Competition 13 01-30-2005 04:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
