79 f150 swap out diff to a 02 f150 with disc
hi im new on the site just wanted to see how much work it would be i have a 79 f150 2wd and i have lightning diff with disc i know the shaft is diffent but will it mount up the same to the leafsprings is my question and with any info would be good thank you guys
I am soooo glad you did some deep homework on this and have already thought this through.
Just measure for width, narrow the housing and axles, cut off the mounts, install new or reposition the mounts compatible with the old leafs, shock brackets, and adapt the driveshaft. Gonna have to adapt, front to rear or vice versa, the new wheel bolt pattern cuz an 02's is metric... Or carry two spares.
Simple.
Thanks for the question!!
Simple.
Go measure and compare. Anything is possible given proper engineering and fabrication skills.
I think you should install the new axle behind the 9" to make it a tandem axle 6x6; if you really wanted to get crazy you would put dual wheels on both of the rear axles.. I would recommend a chain drive to deliver power to the rear most axle.
A wheel adapter will let you interchange the metric/english rims.
Btw... Stupid question = stupid answer.
nobodyspecial
04-06-2007 02:56 PM
rocketman442
04-02-2003 10:08 AM
