sector shaft question '55 F100 - Ford Truck Enthusiasts Forums
S. California Chapter Join Chapter, Leader: wpnaes
Old 03-26-2013, 11:33 AM
my55fordpkup my55fordpkup is offline
my55fordpkup is starting off with a positive reputation.
Im currently rebuilding the steering gear box on my 1955 Ford F100 and just put the new roller gear into the sector shaft. Is the gear supposed to be able to spin freely before i put it back in the gear box? I cant get it to move at all. When i put it together i had no problems, everything just slid right in. Also, the stock pin that held the original sector roller gear in place was mushroomed on both ends. The new pin is hardened steel and i have no idea how i would mushroom the ends. Would it be a problem if i put a tac weld from the pin to the sector roller gear housing?
If anyone could shed some light on this itd be much appriciated!
Thanks.
Parts source for steering Gear?? jjreagan 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-21-2014 04:30 AM
Sector Roller gear 1955 F-100 question.... my55fordpkup 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-28-2013 10:56 AM
1956 Steering Sector Roller Osubuki 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-23-2012 05:57 PM
worm gear sector shaft replacement 57_ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 10-17-2005 08:56 AM
Steering Box rebuild: sector shaft bushing installation help needed (59 F100) VespaJay 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-11-2004 10:43 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1955, f-100, f100, rollergear, sectorshaft, steeringbox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
