Warm starting problems - Ford Truck Enthusiasts Forums
Old 03-26-2013, 12:32 PM
acdc acdc is offline
acdc is starting off with a positive reputation.
Arrow Warm starting problems
I have a 1996 F150 4 wheel drive 5.8L
When I start it cold no problem. When I
cut it off for a short time it is hard to start
and smells like it is flooded once it starts.
It cranks and cranks before starting.
If I let it set for a while it fires right up.
Any suggestions?
Thanks
Old 03-26-2013, 12:54 PM
stewart89 stewart89 is offline
stewart89 is starting off with a positive reputation.
Does your truck idle nice or does it sometimes idle high? Any surging or choking?
Old 03-26-2013, 01:14 PM
None of that. This just started out of the blue.
Old 03-26-2013, 01:28 PM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
Any suggestions?
Thanks
When you turn the key to run (not start), does the fuel pump run for 1-2 seconds then cut off, or, do does the fuel pump run continiously ????
Also, have you checked for any trouble codes yet.
Bob
Old 03-26-2013, 01:59 PM
I agree to see what codes are present.
Old 03-26-2013, 02:09 PM
I haven't checked codes yet.
Listened for fuel pump and it is doing the normal thing.
Cuts off after a couple seconds.
Old 04-14-2013, 11:46 AM
Checked codes
I checked the codes and fixed the egr code.
Fixed the O2 sensor code. Now I have no codes but still the same
problem along with high idle and rough running. HELP
Old 04-16-2013, 11:14 AM
HELP
finally got codes P0118.
Any thoughts?
2006 F450 6.0 Delay In Cranking jbodman 1999 to 2016 Super Duty 5 12-11-2013 12:37 PM
crank crank crank 40dog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 09-19-2008 09:00 AM
Cranking problem developed whitesdford 1999 - 2003 7.3L Power Stroke Diesel 8 01-10-2008 09:24 PM
My 92 Ford 7.3L bus wont start! Help me! raceopticsbus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 02-13-2007 07:26 PM
Crank and crank no start, then runs great! HELP! jackone 1968-2013 Full Size Vans 6 09-20-2005 09:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
