Econoline horn brush bushing - Ford Truck Enthusiasts Forums
Old 03-25-2013, 10:38 PM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
My 65 Econoline was missing some horn parts in the steering wheel. I've mostly got it worked out except for the bushing that the horn brush passes through.
I found a diagram that lists this part as 13A822 (I assume there is a C0xx or C1xx prefix to that number... not sure what it is).
Does anyone know a source for this part?
It looks like a simple part to improvise, but I have no good picture of it. Can someone describe how the brush fits in the bushing? Is it a single piece, or is it multiple pieces? I'm guessing there is a flange on the bottom and the brush's spring tension keeps the bushing in place. Is there something that keeps the brass cap of the horn brush in a certain place? Is the inside diameter of the bushing equal to the carbon brush, or equal to the brass cap? Is the brush inserted from the top, or from the bottom?
Too many words for such a stupid-simple problem. Any help would be appreciated.
kjhales
Old 03-30-2013, 07:31 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by kjhales View Post
My 65 Econoline was missing some horn parts in the steering wheel. I've mostly got it worked out except for the insulator the horn brush fits into.*
I found a diagram that lists this as basic part number: 13A822
Welcome to FTE
C1TF-13A822-A .. Horn Brush Insulator / Obsolete
1961/74 Econoline // 1961/65 F100/250 4WD / 1961/66 F350/1100 / 1966 F250 4WD
GRIFFEN FORD in Louisburg NC has 1 = 919-496-4169.
DICKERSON MOTOR CO. in York SC has 2 = 803-684-4225.
KINSEL L/M in Beaumont TX has 10 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
DON SANDERSON FORD in Glendale AZ has 38 = 623-842-8643.
1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com / The little charmer is shown here: Illustration Section 138, Page 1.
* Insulator fits into a hole on the outside of the steering wheel, below horn button or ring. Then the brush (COAF-13A821-A) fits into the insulator. Make sure the brush's copper wire hasn't snapped.
horn button spring centralNH 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-17-2014 09:51 PM
64 F-100 Horn problem sleddog60 1961 - 1966 F-100 & Larger F-Series Trucks 5 05-18-2009 10:29 PM
Horn - rebuilding everything inside the cab johninraleigh 1961 - 1966 F-100 & Larger F-Series Trucks 5 01-16-2007 05:11 AM
'68 horn contact brush assembly -- need two? eclectix 1967 - 1972 F-100 & Larger F-Series Trucks 11 11-16-2004 04:26 PM
No/Low Cost Parts Cleaner Torque1st Garage & Workshop 1 05-06-2002 10:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
