3 spd Shift Column..to keep/not keep??
Hi guys,
Just curious of some opinions of different folks who've done this thing a time or two. I am getting into my old 52 Ford, and with having an automatic transmission and a lokar floor shifter, I am considering removing the shifting column from my steering tube. I've seen several trucks where the shifting lever only has been removed, then some where the whole shift column has been removed.
What's your take on this? I don't have any plans of going back to a column shift so I'm thinking of just removing it.
I'm just looking for opinions really, I don't suppose it's much of a technical issue.
Thanks again.
Jon Preston
Thanks again.
Jon Preston
Find somebody who is scrapping out a stock floor shift steering column and swap out the whole tube. Otherwise you end up with the top of the shifter still there. Also need to make a plate to cover the hole in the floorboard, and replace the rubber collar that seals to the floormat. What did you do with the clutch pedal?
This is what I will be doing with my F4. The pedal will be retained in position by an under cab spring. I will attempt to use the original but modified crash box handle and **** with the Lokar shifter. Shifter DD Wed this week.
BigShelby
08-14-2016 06:13 AM
DGMFORD
09-30-2010 10:40 PM
MConstable
03-14-2007 04:04 PM
