How many PSI in air shocks? - Ford Truck Enthusiasts Forums
Old 03-25-2013, 05:28 PM
nick5446 nick5446 is offline
nick5446 is starting off with a positive reputation.
Just realized the air shocks in the rear of my '58 are sitting at 0 (ZERO) PSI. Any idea what they should have in them? I'm sure it's something I'll need to tune to my needs, but I'm looking for a starting point, or a max, if possible
Old 03-25-2013, 07:28 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Wink
What about filling them with nitrogen?
Old 03-25-2013, 07:29 PM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
Well, a long time ago I had some that were rated up to 100 psi, Never ran much more than 50 or 60 psi. Usually the max is stamped somewhere on the body or the cover of the shock.
Old 03-25-2013, 07:51 PM
ibuzzard's Avatar
I'm just teasing you, nitrogen in tires is a joke, to me.
Old 03-25-2013, 08:05 PM
ibuzzard's Avatar
Sorry, double post.
Old 03-25-2013, 08:50 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Nitrogen in the NE is not a joke, as it dosen't freeze as fast as run of the mill air!
Old 03-25-2013, 10:42 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
Quote:
I've always kept a minimum of 25 lbs. in mine for a decent ride and then increase it for heavy loads.
Steve
Old 03-26-2013, 12:53 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
If you can read what brand they are somewhere on the shock body you should be able to go on google and check out information about that shock.
Old 03-27-2013, 10:05 AM
Thanks guys! I'm gonna air them up tonight. I'm excited about the possibility of an improved ride!
Air-Lift bags and Bilstein Shocks just installed, anyone else do this? carrfamilynj 1968-2013 Full Size Vans 6 01-19-2012 12:34 PM
Replacement Steering Stabilizer Shock? mdwilli 1999 to 2016 Super Duty 30 04-21-2009 10:25 PM
Air consumption? riggz General Automotive Discussion 20 05-16-2007 12:55 PM
Front Air Shocks yellow78ford 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-30-2006 04:44 PM
air shock pressure perryphilip 1978 - 1996 Big Bronco 3 03-03-2002 01:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
