i believe i need a carb adjustment - Ford Truck Enthusiasts Forums
Old 03-25-2013, 02:07 AM
kevancurtis kevancurtis is offline
kevancurtis is starting off with a positive reputation.
how do i adjust my carb on my 1965 econoline supervan its got a 240 with a FoMoCo single barrel
Old 03-25-2013, 02:09 AM
oh and it has an electric fuel pump. do i need a inline regulator?
Old 03-25-2013, 02:10 AM
it seems to smoke some and smells rich in fuel
Old 03-25-2013, 10:07 AM
hotstuff hotstuff is offline
hotstuff is starting off with a positive reputation.
the 1 bbl don't like a lot of fuel pressure , around 5 lbs. is plenty . check pressure add regulator if needed
Old 03-26-2013, 11:07 PM
how do i test my fuel pressure?
Old 03-27-2013, 09:22 AM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
The shop manual specifies fuel pressure of 4 to 6 psi, and an unrestricted flow rate of 1 pint per 30 seconds or faster, and stresses the need for pressure to be in correct range. You likely need a pressure gauge to check it.
I also have a 1965 Econoline with a 240 and an electric fuel pump. My pump is the "Mr Gasket" available from Autozone for about $45. And the engine seems to be running a bit rich. The pump claims pressure to be in 4 - 7 psi range, but who knows what voltage they applied to the pump when testing it.
When I finish other tasks that are preventing me from passing inspection (I wanna get it on the road!!!), I may try dropping the voltage on the pump a little to see if that helps; a resistor is probably cheaper than a pressure regulator.
kjhales
how to tune carb anthonym92 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-14-2015 09:40 PM
Adjusting an Edelbrock Carb. skipper Fuel Injection, Carburetion & Fuel System 23 05-01-2015 04:07 PM
'69 360 2-Barrel Carb? 69 F-350 Wrecker 1967 - 1972 F-100 & Larger F-Series Trucks 14 06-11-2014 12:29 PM
300-6 Carb Kit or New Carb? gudone 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-16-2012 11:14 PM
Adjustments for 2150 carb?? 1985ColumbusF150 Fuel Injection, Carburetion & Fuel System 2 10-23-2004 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
