Time to buy some gauges - what are you using? - Ford Truck Enthusiasts Forums
Old 03-25-2013, 12:15 AM
the_auto_tech's Avatar
the_auto_tech the_auto_tech is offline
the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.
I just got the truck back from being studded along with some other upgrades and updates. Truck now has an SCT tuner and 4" straight MBRP exhaust and will have an Atlas 40 FICM soon as well. Currently, Torque is setup to monitor:
Page 1 -
Engine oil temp
Engine coolant temp
Transmission fluid temp
Battery voltage
FICM main power
IPR PSI
Page 2 -
Boost (I've got the boost gauge in the cluster, so kind of pointless)
Current gear
Fan RPM
IPR %
Engine load %
VGT %
It seems besides EGT and low pressure fuel Torque has it covered. I know both of those require a sending unit and temp probe hooked up to a gauge or monitor. Most likely I'll just mount them on the A-pillar as it seems the best location and will be mounting my phone on top of the dash using a phone mount near the A-pillar.
Is there anything else you guys recommend?
Old 03-25-2013, 12:42 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
DashBoss with the EGT and Fuel pressure kit would get you everything without having a need for pillar gauges...
On the 12 Gauge screen I have:
ECT
EOT
Volts
FICM Main
Boost
Mass Fuel Desired
ICP PSI
ICP Volts
IPR %
Trans Temp
Fan Speed
VGT%
Then on 3 screens of 4:
Screen 1:
FICM Synch
FICM Main
FICM Logic
FICM Vehicle
Screen2:
Is my test screen.. I load up my variables there, currently:
Fuel Level
ICP CALC
ICP Desired
EBP PSI
Screen 3:
BARO
MAP
EBP
EBP volts
Currently working on Trans selection and ECT/EOT Spread PID
Josh
Old 03-25-2013, 08:11 AM
I'm perfectly fine with pillar gauges and in fact for certain items I prefer an analog gauge to read them. EGT and low pressure fuel dance around quite a bit and I would prefer them in analog readout whereas all the other listed things (besides boost and HPO PSI) don't really move around much once the truck is up to operating temperature. Boost I am fine with the analog gauge in the cluster and I've got HPO PSI on Torque. Also, there's no reason to go to DashBoss for me, especially when I have Torque already setup and it cost me more to use it compared to just get stand-alone gauges.
Old 03-25-2013, 08:56 AM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
The boost gauge in the dash is not accurate if you are running a tuner, and the reading from the obd 2 won't be either
I'm planning on running a 0-30/40 boost, 0-100 fuel pressure and 1-1600 egt eventually. Isspro ev2
Old 03-25-2013, 09:08 AM
Km1210's Avatar
Km1210 Km1210 is offline
Km1210 has a very good reputation on FTE.Km1210 has a very good reputation on FTE.Km1210 has a very good reputation on FTE.
Another vote for Isspro EV2 gauges.
I have the old school Isspro EV's in my truck and they still work excellent.
Good, quality gauges and are easy to read.
Old 03-25-2013, 09:11 AM
Km1210's Avatar
Miles,
Fo the boost gauge, I would run a 0-40. You guys can crank out more than 30 psi with the 6.0 if you intend on upgrading performance later on. Better to have more than not enough.
Just my .02
Old 03-25-2013, 09:53 AM
Bullitt390's Avatar
DashBoss you choose either boost from the PCM or absolute boost from the MAP.
Josh
Old 03-25-2013, 10:06 AM
acf6's Avatar
Quote:
Originally Posted by Km1210 View Post
Miles,
Just my .02
Ya, I just couldn't remember if they came in 0-30 or 0-40
Old 03-25-2013, 11:24 AM
Km1210's Avatar
You can get them in 0-30, 0-40, 0-60, or even 0-100.
I think 0-40 would be enough unless you're building a race truck.
Old 03-25-2013, 09:59 PM
Quote:
Josh
I was thinking Torque works the exact same way. I guess I just don't really understand needing a 3rd boost gauge for the truck, especially since I have studs. The factory gauge seems to be fairly accurate to me.
What gauges are you ACTUALLY monitoring? Obviously some of those are really only useful if you're having a problem, and most likely you would catch that problem on another related gauge I would think. I just don't feel the need to cycle through a billion gauges.
Old 03-25-2013, 10:06 PM
acf6's Avatar
I really dont even look at my scangauge, it just gets me all worked up if i do. I typically display Volts, FICM main volts, oil and coolant temp. Unfortunately this has been alerting me that i need an oil cooler, as im running a 15* delta most of the time, but its not so bad yet so im putting it off
I really just want a fuel pressure gauge, i feel that is one you should always monitor
Old 03-25-2013, 10:16 PM
I will definitely agree fuel pressure and EGT are ones you should always be mindful of and should be watched any time driving the truck. EOT, ECT, TFT, voltage, FICM main power, and ICP PSI all make sense to watch as "secondary" gauges on Torque. Those will all alert you of any major problems going on. I'm alright with having one page of gauges to look at and couple pillar gauges, but I don't really feel the need to be flipping through pages of readouts on my phone.
Old 03-25-2013, 10:19 PM
Bullitt390's Avatar
I honestly do not pay much attention at this point, and normally do not even fire up DashBoss unless I am traveling farther than normal, or just bored in traffic.
However, what I keep my eye on is Volts and IPR% at idle.
Josh
Old 03-25-2013, 10:20 PM
acf6's Avatar
Can i ask (serious question) why you look at IPR %?
Old 03-25-2013, 10:23 PM
Curious as well. I simply watch IPR PSI.
A-Pillar Guages (3) and Dash-Daq Sarge261 Ford Truck Parts for Sale 2 04-26-2015 08:12 PM
Best prices for A-pillar guages LiftedBlackHD 6.0L Power Stroke Diesel 11 03-29-2015 10:26 PM
AutoMeter Gauge Failure? chrison600 Electrical Systems/Wiring 3 12-18-2014 08:51 AM
Bricknose gauge location options whiteboyslo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-05-2012 11:09 PM
What offocial color is the A-pillar in my truck? jopiel 1999 to 2016 Super Duty 13 08-17-2007 10:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
