transmission shifting observations
So, after having driven the truck for three weeks, here's what is happening with my C6.
The shift from 1-2 is just fine. The shift from 2-3 is fine when the transmission is not yet to temperature. when it gets to temp, what happens is that at the point where it would shift, the tranmission appears to slip out of gear (almost like going in neutral), while you're giving throttle, then, it finally goes into third, after letting the motor rev a lot. If you baby the throttle, then it will properly do the 2-3 shift, but that can be annoying. If I simply manually shift 1-2-3, it works OK, but even waiting to shift from 2-3 at around 35-40 mph sometimes does it a little, but usually not.
Does this sound serious? I can't believe this is a modulator adjustment, since the 1-2 shift is fine.
thanks for any help.
Sounds like a governor issue. The low speed weight could be okay, and be enough to overcome throttle valve pressure but not enough to overcome TV pressure when the trans is spinning quick. When you baby the throttle there is only a little TV pressure, which makes it easier for governor pressure to overcome, allowing the 2-3 shift.
Hey, apologies if all the info wasn't in this thread. Didn't mean to frustrate. But after doing some research on the function of the kickdown rod, it's purpose is to force the transmission back to second, from third. Delaying shift points, on the other hand, is controlled by the modulator. So really, me leaving out the part about having/not having the kickdown rod doesn't matter. That I had already ruled out
Again, apologies about referring to another thread. Didn't mean to confuse.
Hmmm. Interesting. Then wouldn't the truck almost never want to shift 2-3 (would want to stay in 2)? But using the gear selector over-rides what is happening. Also, if the linkage is bound, wouldn't think it would 'rev' out of gear. Also note that at light throttle, shifting is OK. The kickdown linkage wouldn't let that happen regardless. But you raise a good point.
