wanted ford 9in rearend-geared between 3.55-3.96 - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 03-24-2013, 02:32 PM
Dtmaster2008's Avatar
Dtmaster2008 Dtmaster2008 is offline
Dtmaster2008 is starting off with a positive reputation.
Im looking for a different rear end for my 76 f-100, currently has a 300i6 and the 3.00 hi-speed rearend doesn't do it much justice pulling wise. If anyone has one geared from a 3.55 to 3.96 and be interested in a swap please contact me via PM and I will get back with you as soon as possible, thanks.
Old 04-14-2013, 04:38 AM
abad6t6 abad6t6 is offline
abad6t6 is starting off with a positive reputation.
Ford 9 inch rear gear ***.
I have a 4.11 or a 3.60 for parts or repair available.
Old 04-14-2013, 07:29 AM
Area351's Avatar
Area351 Area351 is offline
Area351 is starting off with a positive reputation.
I have one that is complete with 3.55's.
You didn't specify your location though. LMK
Old 04-14-2013, 09:54 PM
mechanic58's Avatar
mechanic58 mechanic58 is offline
mechanic58 is starting off with a positive reputation.
I PM'd you - it would help if we knew your location.
Old 04-15-2013, 07:15 PM
yes, sorry Im currently located in central GA, so that probably knocks a few of my options back a little.
rearend help fifth wheel 1994.5 - 1997 7.3L Power Stroke Diesel 10 10-13-2010 03:20 PM
hi gear rearend charlie92/7.3l 1994.5 - 1997 7.3L Power Stroke Diesel 22 02-18-2010 07:47 AM
89 F150 Gears Drockstar 1987 - 1996 F150 & Larger F-Series Trucks 2 07-11-2007 02:45 PM
86 ford bronco rearend 8.8 and 9" Ford_Eddie_Bauer Clutch, Transmission, Differential, Axle & Transfer Case 3 08-14-2005 07:47 PM
rear-end roar with 3.73 gears on 2003 F150 4x4 montu Clutch, Transmission, Differential, Axle & Transfer Case 6 03-31-2003 12:32 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
