Transmission fluid going somewhere
Hi Everyone,
There was an earlier post by my son (ornonic), engine trouble I think we have that problem under control, now I have a question about the transmission fluid, We are loosing a lot of fluid, and do not know where its going. no puddles under the car. I was thinking it could be leaking inside the radiator. We flushed the radiator three times. twice with fresh water and once with a flush cleaner. took it for a long ride and no more fluid loss. I would think by flushing the radiator it would leek worse not get better but it also maybe sporadic at leaking.
Thanks in advance for all help you guys are the best
Thank You
There was a lot of smoke coming out of the breather but has stopped after flushing both the engine and the radiator.
PS there is the button on the shifter ****
Would have been . If no external leaks , sludge in coolant , loosing fluid . Sounds like the cooler in the radiator is bad . Make sure it isn't going into the Tcase . If it was it should start leaking from the rear seal . I see that on GM , don't remember a Ford doing that, just a thought !
oakleysfire
6.4L Power Stroke Diesel
01-30-2016 10:24 AM
djordan
1997-2006 Expedition & Navigator
15
12-11-2013 09:42 PM
86 F-250 Diesel 4X4
08-01-2008 11:06 AM
TexasDeeva
07-08-2004 10:07 PM
