200amp Alternator Install - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 03-24-2013, 04:12 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
The so called drop in 200amp alternator aint so.
The area circled sits about 10mm lower than the stock at the front and back.
So you are going to need a grinder.
take a little of the bracket and all is good
Old 03-24-2013, 04:27 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Brian:
1) good to see you wearing the Taiwanesse saftey boots!
2) was the grinding of the mount the only mod necessary to fit the 200 amper?
3) How much cheaper was it than the FA $6000 replacement, w & w/o freight?
4) How long were you waiting & which transport option did you go for?
Back on the road again?
Old 03-24-2013, 05:23 AM
$250 Delivered. And it took 11 days.
Yes the grinding is all that is needed.
Not on the road yet. I cracked my Map sensor when I was putting the IC tube back on. I tried super glue but she is leaking like a sieve. Found one down in Victoria. Hopefully get it by Tuesday.
Old 03-24-2013, 07:31 AM
Something like this?:
3 BAR MAP SENSORS DELCO STYLE TURBO SUPERCHARGED WITH PLUG | eBay
except you'd need a 4 bar capability (atmosphere + 45 psi)?
Old 03-25-2013, 06:34 AM
Got a Problem ChunderDownUnder Australia Chapter 17 06-08-2015 08:27 PM
Pillar Pod Aussie style ChunderDownUnder 1999 - 2003 7.3L Power Stroke Diesel 20 01-06-2015 09:14 AM
Rotational Velocity test ChunderDownUnder 1999 - 2003 7.3L Power Stroke Diesel 9 10-08-2014 04:40 PM
need a transmission shifter braket wth pto WideOpenFord 1999 - 2003 7.3L Power Stroke Diesel 1 07-11-2014 04:58 PM
Latest additions.... nascar88ford 2004 - 2008 F150 3 08-07-2009 06:01 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
