Stering and front end noise - Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
Old 03-23-2013, 10:06 PM
hzwhx8 hzwhx8 is offline
hzwhx8 is starting off with a positive reputation.
Hey everyone Iím kind of new to the forum and need some help. I have a 2000 Ford Excursion and my truck sways side to side when I am driving and is making some sound as if there are loose joints in the front. It seems the faster I go the harder it is to control. It seems like whenever I attempt to go straight I have to almost immediately turn the steering wheel either left or right to make it go straight. If I go over a speed hump or hit a crack in the road I hear the loose joint noise. I took it to a two different Ford dealers and a local shop and they told me my wheel hubs are fine, my tie rods are fine, and my gear box is fine. I also just replace all of my shocks. Iím planning on driving it down to Florida in two months and would like to have this fixed. Does anyone know of a good Ford specialist shop in the DC, MD or VA area I can go to.
Please Help!!!!!!!!!!!!
Old 03-24-2013, 01:23 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Check your rear wheel bearings. I've had luck at Apple Ford in Columbia, MD.
I wouldn't drive it much in that condition... you might find yourself in the ditch - at best!
Old 03-24-2013, 01:56 PM
Apple Ford was one of the dealers I took it to. Any other suggestions or maybe you can give me the name of the rep you dealt with.
Old 03-24-2013, 02:04 PM
BPofMD's Avatar
Posting Legend
Sorry it was too long ago....but it's hard to believe that they tested the truck and gave up on it! Did they DRIVE it?
As I said... jack up the rear end and see if either or both of the rear wheels bearings are bad. If as bad as you say, the wheels should be really unstable.
Old 03-24-2013, 02:23 PM
Yes they did a test drive. But I will jack up the rear and check the bearings.
Thanks.
Old 03-24-2013, 02:50 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Check the rack and pinion coupling joint between the steering shaft and the rack.
Old 03-27-2013, 09:47 PM
FYI guys I found out the issue with the steering. It was the gear box.
What propshaft to use? (4x4 swap) Truckandute 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-28-2014 02:42 PM
Input Courtney Williams 6.0L Power Stroke Diesel 32 01-07-2013 10:43 AM
New EX and New forum user! TexasEX2K Excursion - King of SUVs 15 07-05-2012 11:46 PM
2010 - Edge Noise 2010Edger Crossovers 4 04-30-2012 07:23 PM
Fruit Punch Update! Putting a 390 into my í77 Free Wheeler FruitPunch 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-04-2010 02:46 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
