AccurateDiesel injectors - Ford Truck Enthusiasts Forums
Old 03-23-2013, 07:20 PM
JHoffman93's Avatar
JHoffman93 JHoffman93 is offline
JHoffman93 is starting off with a positive reputation.
What is the general consensus of AccurateDiesel's reman injectors? I'm on a tight budget but the injectors are long over due for a change. I like the price but are they good injectors. Anyone have personal experience good or bad that they could share?
Old 03-23-2013, 07:46 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
I got mine from them. they run fine. seems like good customer service. overall i am happy with them.
Old 03-23-2013, 09:25 PM
Fordboy350 Fordboy350 is offline
Fordboy350 is starting off with a positive reputation.
I got a set of injectors and an injection pump from them as well. 10000km on both and all is well. Great service from them. I would recommend them.
Any luck using these glow plugs?? jeepnatv4life Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 11-21-2014 06:06 PM
High pressure oil test via IPR bluebird5 6.0L Power Stroke Diesel 7 12-19-2013 04:17 PM
Head stud Q batchman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 09-01-2013 09:18 AM
Off-brand glowplug advice 7.3 Xenthrax Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-20-2013 11:36 PM
Vacuum pump connections needed wmjasonward 1999 to 2016 Super Duty 0 12-21-2012 04:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
