battery isolator questions - Ford Truck Enthusiasts Forums
Old 03-23-2013, 04:13 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
Ok im thinking of installing a battery isolator for when I plan to let the truck sit for weeks on end to prevent the battery from being drained (aside from the usual start to keep it running well) during the summer when I usually ride my motor bike more so was wanting to know if the battery isolator is worth it, even if its nothing more then a theft deturent type thing Im just curious if anyone has such a device in/on there truck and if its worth buying/installing one...
Old 03-23-2013, 04:16 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Why not just pull the negative battery cable when you plan to let it sit? It would cost nothing and for sure would be reliable..
Old 03-23-2013, 04:36 PM
Jaime74656's Avatar
Jim
Quote:
I can and was planning to go that route, but I was thinking of the radio and don't want to really loose the settings and have to reprogram the thing each time when reconnecting the battery cable...thats the only reason I was thinking of one as they usually have a by pass wire that is used to keep the radio alive so it won't loose its settings and for the clock.
Old 03-23-2013, 04:45 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
If you're going to let it sit for long periods of time, I'd recommend a battery tender over disconnecting the battery. Keeps the battery charged and conditioned, which makes it last longer.
https://www.google.com/shopping/prod...ed=0CFgQ8wIwAA
Dual Battery configuaration and placement cadjak 1968-2013 Full Size Vans 35 09-16-2015 09:12 PM
Isolator or relay for dual battery system??? beratte Electrical Systems/Wiring 39 02-15-2015 04:01 AM
Wireing Diagram-Battery Isolator Help Ultraute Electrical Systems/Wiring 4 12-12-2004 12:05 AM
wiring a battery isolator rrawlins Offroad & 4x4 5 10-26-2003 09:31 AM
Battery isolater wiring help 78bigunns Electrical Systems/Wiring 3 03-06-2003 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
