1989 Negative battery cable location
Well I have almost went thru everything to get truck to start. https://www.ford-trucks.com/forums/1...l#post12976634 . Now going to do negative cable it sure is hard to get to. When I buy a new one where an easy spot to place it on the frame or engine not sure. thanks
My '97 ground cable has an eyelet on the end and another near the end. The one near the end goes to the top of the frame near the right motor mount and the one on the end goes to the right front of the block.
But what I prefer is running the ground cable to one of the starter bolts, then run another heavy cable from the same bolt to the frame. That makes sure you've got good connection to the starter.
columbia1spring
09-22-2017 01:44 AM
1986F150six
17
06-20-2013 07:09 PM
DBrawley
11-14-2011 05:10 PM
