Tranny Upgrade Help, IDK what im doing...
Well here, Ill just pose my base question. I am getting a free rebuild under warranty from my builder. He will completely rebuild it replacing all the broken or worn parts with new stock ones for free. I want to upgrade some of these parts however and have about $1500 to do so (this includes the TC). So I want to find the best combination of parts and a TC for my application that will be under that $1500. I use my truck for a daily driver, and I want it to last. But i also want to take it to the track a couple times to see what she can do. I want a transmission that will hold up to 400-500 hp for many miles.
Wow that sounded really demanding haha. Iv made a parts list with a bunch of stuff. I know alot of the options overlap and what not but here is a list with prices and links to each part. Hopefully you guys (who are awesome btw) can help me decide what I do and dont need.
Input Shaft-$150-300
http://www.ebay.com/itm/FORD-4R100-TRANSMISSION-INPUT-SHAFT-BILLET-300M-HARDENED-STEEL-/251222605259?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D6435960255746717945%26pid%3D100033%26prg%3D1011%26rk%3D1%26sd%3D251222605259%26
or
John Wood Automotive - Products
Intermediate Shaft- $50
Valve Body-$250
or
BTS valve Body
or
https://racerxusa.com/product_info.p...919f87f994d3b3
Spiral Snap Ring- $15
http://www.ebay.com/itm/E4OD-4R100-OVERDRIVE-SPIRAL-SNAP-RING-SONNAX-36744-01-/290452526592?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43a051d600
ZPAK- $120
http://www.ebay.com/itm/E4OD-4R100-ZPAK-INTERMEDIATE-RAYBESTOS-Z-PAK-1989-ON-/260112093279?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c8fe3905f
Direct Powerpack-$100
http://www.ebay.com/itm/E4OD-C6-4R100-ALTO-RED-EAGLE-DIRECT-POWERPACK-1966-ON-/260118927042?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c904bd6c2
Intermediate Powerpack
http://www.ebay.com/itm/E4OD-4R100-ALTO-RED-EAGLE-INTERMEDIATE-POWERPACK-89-ON-/260041619181?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c8bb036ed
Coast Clutch Powerpack that works with Cast Iron Coast Drum
http://www.ebay.com/itm/E4OD-4R100-ALTO-RED-EAGLE-COAST-POWERPACK-89-99-/260041619137?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c8bb036c1
Torque Converter $600-1000
4R100 Stage 4 Torque Converter
or
or
Stallion Torque Converters | Precision Industries
link>>> http://www.converter.com/images/stal...owerstroke.pdf
4R100 Precision Industries "Stallion" 3-Clutch Power Stroke Torque Converter :: FORD Stallion Torque Converters :: Pro-Built Automatics
Cast Iron Coast Drum w/ new planetary- $350 __From builder or….
Sun Coast Diesel Transmissions*-*Ford 4R100 4 Disc Coast Clutch Drum | Catalog Products | Sun Coast Diesel Transmissions
Overdrive Powerpack- $75
http://www.ebay.com/itm/E4OD-4R100-ALTO-RED-EAGLE-OVERDRIVE-POWERPACK-1989-97-/350025150101?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item517f1fee95
Front Hub to Forward Drum Washer-$5
http://www.ebay.com/itm/C6-E4OD-4R100-METAL-FRONT-HUB-FORWARD-DRUM-WASHER-/260164320557?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c93007d2d
Possible complete kit, but need to see if he can make the kit for the Cast Iron Coast Drum Style- $500
http://www.ebay.com/itm/4R100-ALTO-RED-EAGLE-KOLENE-FRICTION-STEEL-KIT-98-ON-Powerpacks-Heavy-Duty-/290463849697?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43a0fe9ce1
or
Sun Coast Diesel Transmissions*-*Ford 4R100 Xtreme Rebuild Kit 1999-2003 | Catalog Products | Sun Coast Diesel Transmissions
Do I want this? Bushing kit- $65
http://www.ebay.com/itm/4R100-FORD-BUSHING-KIT-w-TEFLON-TAIL-BUSHING-1998-ON-/290404880285?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item439d7acf9d
Do I want this? Overdrive Sprag Assembly- $100
http://www.ebay.com/itm/E4OD-UPDATED-2ND-DESIGN-OVERDRIVE-SPRAG-ASSEMBLY-89-ON-/260157170225?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3c92936231
Do I want this? Boost Valve and Sleeve Kit-$40
http://www.ebay.com/itm/E4OD-4R100-NEW-BOOST-VALVE-SLEEVE-KIT-SONNAX-/8075009815?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e14edf17
Steel OD Planet Kit-$100
http://www.ebay.com/itm/E4OD-4R100-FORD-LINCOLN-STEEL-OD-PLANET-KIT-/8075009783?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e14edef7
Center Support Kit-$90
http://www.ebay.com/itm/E4OD-4R100-NEW-UPDATED-BEARING-TYPE-CENTER-SUPPORT-KIT-/8075009842?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e14edf32
Servo Piston-$13
http://www.ebay.com/itm/E4OD-4R100-UPDATED-NATIONAL-BAND-SERVO-PISTON-NEW-/8075009850?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e14edf3a
Solenoid Pack-$240
http://www.ebay.com/itm/Ford-4R100-98-2005-Solenoid-Pack-E4OD-Transmission-Electronics-Powerstroke-Only-/380604794181?pt=Motors_Car_Truck_Parts_Accessories&hash=item589dd04545&vxp=mtrDual Load Center Support-$230
Sun Coast Diesel Transmissions*-*Ford 4R100 Dual Load Center Support 1989-1997 | Catalog Products | Sun Coast Diesel Transmissions
Line Mod Valve-$32
Sun Coast Diesel Transmissions*-*Ford 4R100 .500 Line Mod Valve 1989-2003 | Catalog Products | Sun Coast Diesel Transmissions
Thanks so much for any help/suggestions.
or
Valve Body-$250
or
BTS valve Body
or
ZPAK- $120
or
or
or
Servo Piston-$13
Solenoid Pack-$240
Line Mod Valve-$32
I really don't think what you're looking to do is possible on that budget. Others will chime in but, a quality TC is going to cost almost your whole budget. I would use a precision industries torque converter. I also truely believe that stock parts are not going to hold up to 400-500HP.
Adding up the parts you have listed above looks like you are over budget. I would just get it rebuilt on stock parts for what's covered and start saving for a new transmission.
I can't see dropping $$$$$ on injectors, turbo and such to bring you to 400-500 HP and not have a reliable transmission behind it all.
on
Input Shaft-$150-300 I would use one from a trusted vendor. Had one fail and it was "supposedly" a 300M shaft..
Ford 4R100 Transmission Input Shaft Billet 300M Hardened Steel | eBay
or
Intermediate Shaft- $50 Good upgrade
Valve Body-$250
or Your choice.
BTS valve Body
or
Spiral Snap Ring- $15 Good update. Also part of a TransGo Tugger kit or Sonnax Sure Cure
E4OD 4R100 Overdrive Spiral Snap Ring Sonnax 36744 01 | eBay
ZPAK- $120
E4OD 4R100 Zpak Intermediate Raybestos Z Pak 1989 On | eBay
E4OD C6 4R100 Alto Red Eagle Direct Powerpack 1966 On | eBay
E4OD 4R100 Alto Red Eagle Intermediate Powerpack 89 On | eBay
E4OD 4R100 Alto Red Eagle Coast Powerpack 89 99 | eBay
or
or
E4OD 4R100 Alto Red Eagle Overdrive Powerpack 1989 97 | eBay
C6 E4OD 4R100 Metal Front Hub to Forward Drum Washer | eBay
Possible complete kit, but need to see if he can make the kit for the Cast Iron Coast Drum Style- $500 Get the Powerpacks in kit form, if possible. Less expensive that way. IMHO, for that price, it should include a gasket kit and molded pistons.4R100 Alto Red Eagle Kolene Friction Steel Kit 98 on with Powerpacks Heavy Duty | eBay
or
Do I want this? Bushing kit- $65 If bushings haven't already been changed. Should have been done already. 4R100 Ford Bushing Kit w Teflon Tail Bushing 1998 On | eBay
Do I want this? Overdrive Sprag Assembly- $100 Will be needed when changing to cast iron coast clutch.
E4OD Updated 2nd Design Overdrive Sprag Assembly 89 On | eBay
Do I want this? Boost Valve and Sleeve Kit-$40 Good update. It is also part of TransGo Tugger kit, if you went that route. E4OD 4R100 New Boost Valve Sleeve Kit by Sonnax | eBay
Steel OD Planet Kit-$100 Not necessary. Diesel applications are already steel.
E4OD 4R100 Ford Lincoln Steel OD Planet Kit | eBay
Center Support Kit-$90 Not necessary. Your year transmission has the ball bearing update. Get the machined aluminum housing part of the center support with spacer ring instead. E4OD 4R100 New Updated Bearing Type Center Support Kit | eBay
Servo Piston-$13 Replace. Rebuilder should furnish.
E4OD 4R100 Updated National Band Servo Piston New | eBay
Solenoid Pack-$240 Replace as precaution, but not necessary if working fine.
Ford 4R100 98 2005 Solenoid Pack E4OD Transmission Electronics Powerstroke Only | eBay
Dual Load Center Support-$230 Would not use. Mine had a failure due to lack of lubrication to bushing. Poor design.
Line Mod Valve-$32 I used a .427 valve instead.
or
Valve Body-$250
or Your choice.
BTS valve Body
or
ZPAK- $120
or
or
or
Now I think Roland touched on alot of the parts you are talking about and I agree with him 100%. But here lies the problem you can't build your tranny & TC for under $1500 in parts to hold up to 500hp. It just won't happen so personally give up on wanting to make 500hp or plan on spending alot of money on the trans. You say you don't tow heavy well when you are making 400-500hp that is about the same as towing heavy as far as wear and tear on the trans parts if NOT worse!
Now like I said I agree with Roland on the parts but Roland and I believe in using 2 different clutchs. I like BW clutchs and he likes Alto. But he is making 500hp and I'm NOT and the BW clutchs work for my needs. And whatever clutchs you go with use the same one all the way through your build. Don't use the Zpak with Alto's. Now I like the Zpak clutchs but honestly they are more geared towards gassers and very fast gassers with head snapping shifts. All clutch materials work differently.
When it comes to valves and OD retainer rings you need to decide whether to go with the Sonnax or Thugger kit. I would talk to your builder on that. Roland used Thugger and I myself used Sonnax. They both are very good but they just go about solving problems alittle differently. Here is the Sonnax kit I used. Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts
And like Roland said do NOT use that dual load center support kit you had posted. He had learned that one the hard way. Now here is the center support I used #A36636BK or you can use the D36636BK https://www.wittrans.com/SchematicPa...0&LinkCode=636
Also this kit comes with Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts
I believe in using center support feed bolt shim Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts
Now I would also like to add the key to a good rebuild is not only parts but getting all end plays and stacked clearances set within specs. You might have to pay your builder alittle more to spend the extra time to get the right size retainer rings and right clearances. And that alone will make a big different in the build. Blueprinting a trans takes time and time is money.
Thanks for the suggestion guys. Ill have to talk with my builder more this coming week. I needed some ideas and combinations that others are using. And you guys gave me that. Ill probably give up on making 500hp for right now. Right now im still on stock injectors so Ill be fine for a while.
Cougar54
08-13-2014 11:57 PM
61 uni
12-20-2007 12:18 AM
rnelson664
01-09-2007 08:49 PM
