1987 f150 fuel system problems - Ford Truck Enthusiasts Forums
Old 03-23-2013, 12:04 PM
wingless93 wingless93 is offline
wingless93 is starting off with a positive reputation.
I actually have two problems. one is the fuel gauge. when i fill the truck up it reads full then after driving for a while it reads empty even though the tank is not empty. there is no in between as the needle goes straight from full to empty. it does this with both tanks. also i noticed fuel leaking down the front of the front tank so i switched to the rear tank. the fuel still is leaking down the front of the front tank. I ran the front tank empty before switching so i have no idea where the leak is originating. does anyone have any ideas?
Dual fuel tankS mike L 1987 - 1996 F150 & Larger F-Series Trucks 39 11-23-2014 10:33 AM
Fuel Gauge Question Aeckman 1987 - 1996 F150 & Larger F-Series Trucks 1 05-09-2014 10:55 PM
1989 F250 diesel fuel gage airhead General Diesel Discussion 0 08-06-2012 11:16 AM
Fuel Gauge Open Circuit Diagnostics Help Franken-Truck Electrical Systems/Wiring 2 12-18-2011 07:20 PM
dual tank problem rogersdan 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2006 01:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
