5 cylinder Diesel in F150's Future?
Old 03-23-2013, 09:08 AM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
I was surfing the web trying to read about the 2014 F150 this morning and came across this article of a 3.2L South African built diesel used in The Ford Escort in Europe. (197hp with 325 lbs. -ft. of torque) Would you buy a F150 with this motor in it? It boasts 60 mpg!
Here is the article:
Is a Five-Cylinder Diesel In Ford's F150 Future? - Farm Progress
Old 03-23-2013, 09:11 AM
Explorer10's Avatar
Explorer10
Explorer10 is offline
I'd certainly take a close look.
Old 03-23-2013, 09:25 AM
PrinceValium
Welcome to FTE!
Interesting stuff huh?
Old 03-23-2013, 10:26 AM
parkland's Avatar
parkland
parkland is offline
60 MPG in a car...
I think it would be in the high 20's in the f150.
Lead Head's Avatar
Lead Head
Lead Head is offline
This is not the engine used in the European Escort, as the Escort used a 1.8L 90HP Diesel. Not to mention the Escort hasn't been sold for ~10 years now. You also cannot directly compare European fuel economy to EPA. European fuel economy numbers are usually inflated 205-40% compared to EPA.
Old 03-23-2013, 07:43 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
That's the motor that may be used in the 2013 ford transit. It's also used in the global ford ranger. There was a sort article about it in the last issue of dieselpower. Can't see it being used in a small escort?
Old 03-23-2013, 10:59 PM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,216 Likes on 799 Posts
I think it could be a home run even though I wouldn't get it for myself. Diesel fuel is too high and maintenance along with initial cost is a show stopper for me.
I can't imagine Ford having 5 engines available in the F-150. Which engine would go?
Old 03-24-2013, 12:23 AM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
ya i cant see them with 5 motor to chose from in a F150 so they would kill one of the V8 i bet! i would guess the 5.0 because the raptor needs a power house to rest on!
Old 03-24-2013, 02:09 AM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
If it came to that, I would bet the 6.2L would be the one on the choping block. Its more of a niche engine. The 5.0L is Fords volume V8, Alot more trucks roll off the dealership lots with the 5.0L than they do with the 6.2L.
Old 03-24-2013, 05:10 AM
03 SVT VERT's Avatar
03 SVT VERT
03 SVT VERT is offline
The 6.2 would definately be the engine cut from the lineup. The Ecoboost and 5.0l make up the overwhelming majority of sales. Not to mention the 6.2l is terrible for Ford's CAFE rating.
Dropping the 6.2l from the F150 has seen passing references from Ford execs quite a few times in the past. Not that long ago Ford wanted imput from consumers on whether they would consider buying an Ecoboost Raptor over the 6.2l.
Old 03-24-2013, 06:26 AM
tseekins's Avatar
tseekins
Fully agreed.
Not surprising at all sir. However, I think that dropping it all together would be a mistake as well. If the decision were all mine to make, I would still offer it in the SVT, Harley and Limited trucks and I would make sure that the company made a huge profit on each sale as a result.
Old 03-24-2013, 08:40 AM
Lead Head's Avatar
Lead Head
It's not like they haven't had 5 engines available in a single F-Series truck before.
In the F-250s, you used to be able to option them with a 4.9, 5.0, 5.8, 7.5 and a 7.3 Diesel. Actually 6 options if you include the Lightning 5.8.
Old 03-24-2013, 10:15 AM
parkland's Avatar
parkland
parkland is offline
I thought the 460 and diesel were only f250 and up options?
Old 03-24-2013, 01:37 PM
Lead Head's Avatar
Lead Head
They were, but you could get an F-250 with all of those engine options.
Old 03-24-2013, 03:13 PM
parkland's Avatar
parkland
parkland is offline
Fair enough, I believe you are right.
Here is my personal guess as to what will happen....
The 6.2 will be gone, I think it was only brought to market to phase out the v10.
I think the 5.0 will be changed a bit into a ecoboost type engine, as it has been pointed out that some of the castings have provisions for such use in the future.
So I think that the f150 options will be 3.7 v6, 3.5 ecoboost, or 5.0 ecoboost for the raptor.
Ford ditched the ranger, because they speculated the only people that bought them wanted low budget trucks, so I expect they will use the 3.7 a lot on XL models.
Then for the super duty line up, I bet either 6.7 diesel, or 5.0 ecoboost will be the options.
I could be wrong though.
In fact, most of the time, I am wrong.
Quick Reply: 5 cylinder Diesel in F150's Future?
