'59 Differential
'59 Differential
What started out as an oil drip from the differential turns into a rebuild.
Question? Did the old timers put a silvery looking grease in the rear end? When I pulled the 3rd member there was a quantity of silver grease in the housing. It didn't mix with the oil. Just wonder what my uncle was trying to do? He's gone and probably laughing at me!
Anyway, the pinion is quite worn and looks like I am going to learn how to rebuild a ring and pinion.
Thought since I had to undo the axles, I might as well replace the bearings and seals. Tomorrow to figure out how to get the inner shaft seal out and where to purchase the pinion and gear.
Any 9" ford will fit. Since you have it out, you may want to consider putting a different ratio differential in it. The original is a 3.7:1. These things were made in many ratios. I put a 3.00:1 in mine and it works great behind by 292, 4 speed. I start out in granny gear, which now works like an actual 1st gear. I can easily comfortably cruse at 70 mph on the highway. 3.25:1 would also be much better.
not mine: Just need to confirm it is a 28 spline.
Vintage 1969 Cougar Ford 9 inch differential rear end 3rd member | eBay
radramrod2
01-07-2013 11:34 PM
psychomech
1999 to 2016 Super Duty
03-18-2008 10:51 AM
KJKozak2
06-21-2002 07:40 PM
