2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expedition problems HELPPPPP!!
Old 03-22-2013, 08:25 PM
jamull2852's Avatar
jamull2852
jamull2852 is offline
My wife has a 2007 Expedition Limited with 126k miles on it. It started to shake around 40mph a few months ago and only seemed like it would happen when trying to go up a bridge or pass a car. I thought it might be the Coil over packs and took it to a mechanic and he tested it and it showed nothing. He changed the fuel filter and put a cleaner in the gas tank and it did feel better for a few weeks until the shaking started to come back. Well the check engine light came on and I tested it at autozone and it said Misfire cylinder #4. THen the light cleared. So now I dont know if its the sparkplug or the coil over pack. She just called me while Im at work and said as she was backing into the drive way it started to shake really bad and make a loud spudder noise but she said it was hard to explain the sound. I never felt or heard this while going to slow into a drive way. What could it be? its driving me crazy at work not knowing if the motor is shot or not.
Cliffs
-2007 expedition
-126k miles
-Shakes and spudders at 40mph when passing/going up hill
-engine light showing misfire on cylinder #4
- tonight it started to shake really bad and make a loud noise just backing into the drive way.
Old 03-23-2013, 12:04 PM
expoman55's Avatar
expoman55
expoman55 is offline
07 shudder
Don't know if it is the same 'shudder' so to speak however, that said, my 05 (115k miles) did the similar one day and threw a code for left bank timimg retard. End of the day was not timing phazers it was a broken chain guide. Stealer said $5k to fix and 60 hours of labor.. of course I signed right up NOT..... I went to my local mechanic.. 8 hours later, chainguide kit from Autozone $225. Repair was 600.00 YEP works like a charm.
All the best
Old 03-23-2013, 02:56 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Have you ever changed the plugs? Does the CEL blink or just stay on?
Old 03-23-2013, 09:27 PM
irishpride1's Avatar
irishpride1
irishpride1 is offline
change the cyl 4 coil pack.
Old 03-23-2013, 09:40 PM
jamull2852's Avatar
jamull2852
I bought the truck with 60k miles and far as I know the plugs haven't been changed but I'm going to bring it to the mechanic this week for new plugs and all new coil packs. Hopefully this fixes it. The CEL came one one day and started blinking when my wife tried to pass going up hill and started to shake she said. I went to auto zone that day and pulled code misfire cylinder #4 p0304. After autozone the CEL has stayed off. Would it be smart to change all coil packs vs just one?
Old 03-23-2013, 09:52 PM
jamull2852's Avatar
jamull2852
Is the spark plugs and coils I need to replace both?
My mechanic said the coils for the local autozone is around $40 for one!! Is this the same thing?
http://www.ebay.com/itm/SET-OF-8-IGNITION-COIL-FD508-DG511-8-MOTORCRAFT-SPARK-PLUG-SP515-/170842215543?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2007%7CModel%3AExpedition&hash=item27c6fd5477&vxp=mtr
Old 03-23-2013, 11:17 PM
5.4T's Avatar
5.4T
5.4T is offline
jegs got a special for 25 $ per coil, I wish they had this deal when I did mines, I would have done it!!!!!!
JEGS Coil on Plug - JEGS
Old 03-23-2013, 11:23 PM
jamull2852's Avatar
jamull2852
Would the ones I posted work? Or they aren't to reliable? I don't want to be changing them soon after changing them now. Motor craft is a good brand, correct?
Old 03-24-2013, 12:46 AM
jdm5630's Avatar
jdm5630
jdm5630 is offline
I would change plugs and coil packs. I had the same problem on my 07. It would shake while going uphill. Changed all sparks and it works fine now. Blinking CEL means misfire. Mine would also have a rough idle while in park
Old 03-25-2013, 02:07 PM
jamull2852's Avatar
jamull2852
Just ordered the coil packs from jegs from the link above. Talked to my mechanic and he said we will start with the spark plugs and coils. Which plugs do you all recomend?
Old 03-25-2013, 02:10 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Motorcraft
Old 03-25-2013, 02:23 PM
berry1234's Avatar
berry1234
berry1234 is offline
Don't use any but the specified Motocraft plugs. Change coil and plug and report back.
Old 03-25-2013, 02:40 PM
jamull2852's Avatar
jamull2852
Is motor craft the oem brand?
And ill keep updating as I go and answer any questions. Thanks guys
Old 03-25-2013, 02:47 PM
berry1234's Avatar
berry1234
Yes, Motorcraft is Fords parts.
Old 03-26-2013, 12:17 AM
Wrench Turner CB's Avatar
Wrench Turner CB
Wrench Turner CB is offline
Any coil pack you buy other than motorcraft is a better COP. The problem in the factory coil over is the "potting"; thist is the stuff used to insulate the windings in the coil. I like using the Acel super coil you can pick up at Advance or Orellys. These are cheaper but last better than the motorcraft. BWD is also a good pick if you have a problem with the bright yellow Accel coil pack
Quick Reply: 2007 Expedition problems HELPPPPP!!
