2001 F150 won't shift out of 1st gear, HELP!
I have a 2001 Ford F-150 5.4L Supercrew that won't seem to shift out of 1st gear. This morning coming out of stop light on the way to work, the truck seemed to jerk when it was supposed to shift into 2nd gear. I was told by a friend that the speed sensor may be it? Any help would be greatly appreciated, thanks!
UPDATE: So I took the truck around the block just so I can get a feel for what is going on. So the truck shifts into 2nd, but not past that. It seems that around 30mph the RPM's go up jump up quickly to 2k+ and no shift or increase in speed. I was reading up a bit on it and came across the possibility of a TPS?
I just got my '00 back from shop yesterday, had identical issue...3rd gear is a direct drive shaft, the splines in the drum hub had stripped/failed, I had other hard part damage as result.
Complete bench disassembly, installed rebuild kit (clutches, bands, filter, bushings, & seals), along with new direct and reverse drums, shell/gear, servos, and piston. Torque converter rebuilt as well, new ATF.
I got three local estimates (SF Bay Area, CA), and looked into online options. Wasn't interested in a junkyard pull.
~$1000 in parts, ~$1300 labor (R&R, +rebuild)
~$2400 total, w/warranty.
I have a thread here about my truck doing that same thing every time it snows. Drive it till it warms up, and let it idle for a half an hour, and the trans shifts perfectly. Something in the electronics gets wet or freezes up and screws up the shifting. I think it's the Manual Lever Position Sensor on the side of the trans, it's also the neutral start switch and the backup light switch. About a hundred bucks at NAPA or 200 at Ford. I'm just going to drive it like that until Spring and dump it on some other poor schmuck.
Millinex
09-30-2023 10:39 PM
BlackCoffee
05-07-2019 04:48 AM
richierand95
1999 to 2016 Super Duty
08-16-2016 07:51 PM
rabeb
02-07-2009 03:03 PM
