best way to test for boost leaks??
Received 3,102 Likes
on
my 02 with 180,000 miles on it has started blowing black smoke, fuel mileage is down to 12mpg on the highway, and i can only hit 25 lbs of boost at wide open off a light.
i think the lower intercooler boots are leaking, but am not sure. what is the best/easiest way to test for boost leaks?
on
on
i am going to look tomorrow. when the dealer said i had 2 leaking fuel lines last month and it would cost $520 to replace them, i climbed up in there and the fuel bowl drain was cracked open.
i closed it and no more leak.
wit me bum leg, i need a ladder to get up into the engine bay to see things.
on
welllll, it ain't the intercooler boots.
sounds like it is coming from the intake at the heads, but i can't hear worth a damn, and i can't see any bubbling with soap water on any possible leak points.
it is a massive leak though, i have a regulator on the compressor side of the hose set to 30 psi, and can not even build any pressure in the system.the intake hose swells pretty good, so i am only feeding it a small amount of air. but as soon as i shut the ball valve off to kill air input, it will empty the system in a second or two.
fuel leak is a mystery too. the fuel filter housing and bowl drain are dry. there is a small puddle in the intake under the fuel bowl, but it smells and feels like oil not fuel..
on
There Re boots down there. I almost guarentree they are leaking especially if yourve never given them any attention. Every few months I go in and tighten my clamps and always find one loose. Now I can do the plenum boots too where as before I didn't tighten them for fear of warping the intakes. The only way to test them is the same thing youve been doing.
on
on
