How do you hot wire? - Ford Truck Enthusiasts Forums
Old 03-22-2013, 01:02 AM
tude's Avatar
tude tude is offline
tude is starting off with a positive reputation.
Ok first off the original truck is long gone.
I have a 7.3 non turbo from a 93 f350 2wd/5speed. This is going into a 75 f250 frame with a 48 IH body. I understand how to make the starter work but don't know what all I need to make it run and shut off.
Ill go to the shop tommarow and take pics of the plugs I really have questions on also.
So far here's what it looks like-
Old 03-22-2013, 05:04 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
all you really need to make the engine run is 12 volts to the fuel shut off switch, and starter power.
but working glow plugs are nice to have.
Old 03-22-2013, 11:42 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
looks like a fun project
switched 12v to the FSS as TJC described is all it takes to switch it on and off. glow plugs are nice to have, many people set them up on a pushbutton if they don't like the factory controller, or you can look in the stickys on top of this page to really understand how the glow plug system works, and see what it takes to wire it up
Old 03-22-2013, 12:41 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
Cold start timing advance & high idle are also nice. The same power source as the FSS can be wired to the engine temp switch, then the other side of the engine temp switch to the cold timing advance and the cold idle solenoid.
Old 03-22-2013, 12:42 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Red wire on IP, there are 3 prongs, if you dunno which is which 12v to all 3 wont hurt anything to start it up. For the glow plugs, assuming everything is intact, there will be two big black / orange wires that went to the fender starter solenoid, hook those to battery power and jump the GP solenoid for 10sec, then jump the starter solenoid and that should get her fired.
Old 03-22-2013, 08:04 PM
tude's Avatar
Here's what I see, this round plug and a ground wire
This plug-
Do I need to do anything with this?
Fuel return?
And then there is this silinoid on the back of the motor.... Not sure what it does but someone added red wires to it.
Old 03-22-2013, 08:11 PM
i ain't rite
the solenoid on the back of the engine is the glow plug controller.
the "fuel return line" correct. that goes back to the fuel tank.
the plug on the trans is for reverse lights.
not sure what the first two pics wires are for.
Old 03-22-2013, 08:54 PM
tude's Avatar
Thank you, ill mark them tommarow when I get in the shop.
And the reverse lights.... Ya they won't be hooked up ill Probibly have fog lights in there somewhere.
Old 03-22-2013, 08:59 PM
First pic is the hot wires for the glow plugs, the connector im not sure, second is the main engine harness i believe. Then fuel return line, then reverse lights, then the wires must be for a push button someone added to run the glow plugs.
Old 03-23-2013, 03:26 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
Pic two is the engain harness,
The red and light green wire is hot in run and start that should make it run,
F350 Tahoe trip with new trailer. Warning: many photos! rangerbait Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 18 07-14-2015 03:51 PM
Finally got a 59 I've been chasing for years tude 1957 - 1960 F100 & Larger F-Series Trucks 34 01-23-2015 11:47 PM
Would anyone use new heads like this? tude 1973 - 1979 F-100 & Larger F-Series Trucks 29 03-13-2014 03:48 PM
Painted and installed bed progress pictures drewduncan15 1973 - 1979 F-100 & Larger F-Series Trucks 8 01-25-2014 01:29 AM
Showing off my 1975 F350 Supercab. LOTS of pictures drewduncan15 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-13-2013 06:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
