HELP****@@@@@ PLEASE differential rebuild I guess
on
1 Post
Shawn, I just did this swap. Prop the biggest hiccup youll run into in a driveway axle swap would be stubborn U bolts holding it in. Start applying rust penetrant early and often and let em soak. They do recommend that you do not reuse them. Not getting into that debate here. Brake jobs are cheap, do it now, with wheel cylinders and center hose. Fresh fluid for the gears. A lil trick to get the ebrake cables outta the backing plates, free the cable from the shoe, then slide a 1/2" boxend wrench over the cable, put pressure and wiggle while pulling on the cable from the rear. Pops right out and smoke your knuckle on the leaf spring. shocks, driveline, vss harness, all simple stuff. Be safe, the truck is held in park by the rear end, so take note. Ive seen it done. As far as going rate for another rear, i cant help, I have parts, now one less 8.8
on
1 Post
Ok more tips: floor jack under the pumpkin then put JACKSTANDS under frame just in front of leaf springs. Leave jack there and start unbolting, leaving the big u bolts for last. Wrap the ujoint with electricians tape to retain caps or they will fall off. Use the jack to pull the housing out. Reinstall in reverse. On the install of the u bolts two things. The vertical alignment of the bolts, as looking from the rear. They will kick out ward when you apply torque. Wear gloves and hold them straight, youll see what i mean. And also tighten the nuts on one bolt evenly, as far as thead engagement. Undue stress that can be prevented. ( yes I was yelling bout the jackstands)
will have to match the other axle's gearset. It makes sense. Your gearset has to
match front and rear.
OP- As mentioned, there are probably a few salvage yards and auto recyclers around where you live that should be able to help you out.
xkpsanit hit the nail on the head! If the u-bolts give you problems, use a cut-off wheel or a torch and they'll be just a memory. Be sure to re-torque the new ones after a few miles/days. Great advice regarding replacing the wheel cylinders and axle seals "while you're in there".
It seems like a daunting task, but it really isnt. The other alternative is to call around and see if there are any good driveline or transmission shops that set up differentials. Buy your own parts and pay to have them installed, however it may cost more than a J/Y piece in the end.
on
1 Post
Forgot about the retorque, poopy. Ive seen diff rebuilds go up to a grand. JY cant be more than $150??? We were just putting wheel bearings/seals in mine, and the crosspin retaining bolt was broke off. Had to blow the cross out with a torch. 3.55's in the parts truck, there is my answer. Had a good vss in it too and now my cruise works. Bonus.
He has a habit of contributing inaccurate information or giving poor advice. A few members here (myself included) have had to correct his information in other threads to ensure the OP doesn't get confused, do something stupid, buy the wrong part, or injure themselves.
dans 51 f2
03-17-2010 03:44 PM
branpollard
12-23-2004 12:40 AM
390GT
02-27-2002 03:55 PM
