Mercury Mariner Problem - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-21-2013, 12:10 PM
ronkur ronkur is offline
ronkur is starting off with a positive reputation.
I have a 2005 Mercury Mariner. It started out by making a loud clunk sound every now and then, but now it seems like something is binding up to the point where the vehicle doesn't want to move. When I'm parked on a slight slope and put the vehicle in neutral it will even stop on it's own. I get noise coming from the passenger side front wheel. I jacked the front passenger side up but can't turn the wheel. Right now I feel the car is undriveable. Anybody have any ideas what the problem might be? Any help would be greatly appreciated.
Old 03-21-2013, 05:42 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
Could be several thing.
Broken axle
Brake pads
Brake rotor
Brake caliper
Best bet is to jack it up and remove the wheel. If you don't see anything take a few pics and post them.
Old 03-21-2013, 11:23 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
If its the brake holding up the rim should get pretty hot.Try driven and see if the left and right seem to be close in temp.To spin the tire you need to raise both front tires off the ground I think.
Old 03-22-2013, 08:32 AM
Plan on checking it out this weekend. Temp outside is in the 20s right now. Too Freakin Cold.
Old 03-22-2013, 11:56 AM
OK. I couldn't resist. I jacked the whole front end up with both wheels off the ground and was able to turn the wheel with NO noise. I took the tire off and checked the brakes, rotor and caliber. Everything looks ok. I'm thinking about putting the front end back down on the ground and jacking the whole back end up and check for noise. Thinking the problem might be the CV joint between the 2 drive shafts. Any other ideas are welcome.
Old 03-22-2013, 11:02 PM
bmuhlbach's Avatar
sway bar end links could clunk its pretty common but that wont effect anything else
Old 03-24-2013, 08:31 PM
Bad news. Jacked that bad boy completely off the ground and found out the noise is coming from the transmission. $$$$$$$$$$$$$ that I aint got.
'02 diesel ec trade for crew cab Biscayne Vehicles for Sale 2 12-22-2012 10:46 AM
Can a front brake caliper have an internal leak ..non-visible externally... nor loss of any fluid... Bones Digger 1987 - 1996 F150 & Larger F-Series Trucks 20 07-09-2012 02:53 PM
Badass Truck? OPINIONS DieselTrap 1999 to 2016 Super Duty 5 05-31-2012 02:35 PM
alternator light on with new bat/alt jsteed04 1987 - 1996 F150 & Larger F-Series Trucks 3 02-03-2012 01:43 AM
A BIT OF NAVAL HISTORY... stu37d General NON-Automotive Conversation 12 01-11-2012 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
