460 "straight up" timing set? - Ford Truck Enthusiasts Forums
Old 03-20-2013, 06:46 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I'm doing a little refresh on the 460 in my 78 F150, its out of a 79 F350. I'm pulling all the emissions stuff, doing plugs/wires/cap/rotor, ederlbrock intake, fenderwell headers, rear sump oilpan/pickup/1 piece oil pan gasket, new oil pump, new water pump, new timing cover (old one was broken), new thermostat, radiator, shroud, radiator cap, etc. As you can guess the motor is torn down pretty good. while I've got it apart I'd like to go ahead and change the timing set. I understand the 70 and earlier timing set is "straight up" and makes more power. The thing is, if you type in 460 timing set at summit racing, they have a few different ones to chose from and they all say you can install them at 0 degrees, +4, or -4. 0 degrees would be "straight up," right? They don't break them down by year so I'm guessing they only make them this way anymore.
I want to get a kit to do cams and springs/retainers/lifters all that while I'm at it but not sure if that will be budgetable this go round.
Old 03-20-2013, 06:58 PM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.
Yes 0 would be straight up.
Old 03-20-2013, 07:18 PM
J ballan's Avatar
J ballan J ballan is offline
J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.
You got er. I went with a comp cams double roller and it seemed to be good quality.
Old 03-20-2013, 07:59 PM
sweet. hard to beat summit's own $38 double roller though. Summit Racing® True Roller Timing Sets SUM-G6630 - SummitRacing.com
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 7 03-20-2017 09:40 PM
Replacing the Oil Pan Gasket on my '84 351W kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 09-27-2016 01:21 PM
common 460 stuff jbehuniak Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 03-04-2016 11:10 AM
IDI Oil Cooler Thread Chevy_Eater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-17-2015 09:17 PM
97 460 Upgrades WarrensE350 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 11-27-2013 10:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
