Hold engine from rotating
Gentlemen, I am in the middle of removing my HPOP. I have the breaker bar on the 18mm fastener on the bolt that attaches the gear to the pump. Catch is I have an automatic! So the engine turns. Rats!
How do you guys hold the engine to keep it from rotating while removing the bolt and washer?
My HPOP pump is bleeding out the “Don’t Remove” plug. Diesel O-rings has me all fixed up with the parts for it and the fuel water separator rebuild.
Thank you for your time,
Don Smith
Don Smith
I just did this last weekend. I used a short pry bar in the teeth of the wheel and a 24 inch breaker bar. Reason I used the long bar was so I could lay across the passenger side battery and pull the breaker bar while holding the pry bar in place. Left hand on the pry bar, right hand on the breaker bar/socket. Worked like a charm!!!
bobbyrjw
04-27-2011 11:43 PM
