fuel pressure tester question - Ford Truck Enthusiasts Forums
Old 03-20-2013, 05:54 PM
99StrokeXLT's Avatar
99StrokeXLT 99StrokeXLT is offline
99StrokeXLT is starting off with a positive reputation.
I'm looking for a gauge or tester kit to check my fuel pressure at the fuel bowl. The fuel pressure tester at sear specifically says not for diesel. Do you think this is just because they are assuming pressure will be above 100psi rating of the gauge in the fuel system or is there another reason the test kit would be incompatible with diesel?
Old 03-20-2013, 06:00 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
The only reason I can think is for some reason there thinking your going to try to test it on the high pressure side.
I opted to just buy a fuel pressure gauge... I hope I don't need it but if I do it's always there
Old 03-20-2013, 06:01 PM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
My opinion is to just get a Isspro ev2 2" gage for inside the cab. Only about 2x or so the cost of a good "test" gage. Riffraf sells them. Fuel pressure is kind of important on these beasts.
Old 03-20-2013, 06:14 PM
I would love to put a permanent gauge in the cab unfortunately I don't know if its the cards. I'm looking to just check the pressure to make sure its shop shape for now as the test kit is only $40
Yea that's what I was thinking they are assuming the pressure will be out of the units range
Old 03-20-2013, 06:19 PM
My pressure is bumped up for my injectors and I'm running 72psi. 100psi gage is fine.
Old 03-20-2013, 06:25 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
Harbor freight is a good place that is where I got mine. You will need an adapter to tap into that port. It is the same as the hpop res plug on top.
Old 03-20-2013, 06:45 PM
honeydew honeydew is offline
honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.
A friend lent me one of those Harbor Freight testers to check my EV2 gauge with, they were within 2 psi of each other. Connected it to the bowl with a schraeder valve and adapter from dieselorings.
Old 03-20-2013, 07:05 PM
I ordered the adapter and valve from Bob last night so I'm all set with that. I didn't think of harbor freight that's a great idea, there's one 20 minutes from me. What did the set up cost there?
Old 03-20-2013, 07:18 PM
$20: Fuel Pressure Tester & Fuel Injection Pump Tester
Harbor Freight is never a great idea but some of their stuff performs acceptably at least once.
Old 03-21-2013, 07:32 AM
koski19 koski19 is offline
koski19 is starting off with a positive reputation.
Quote:
You could go to your nearest Parker store for the gauge, hose and fittings. Here's the link:The-Parker-Store-Hose-Valves-Fittings
They have all the stuff you need to build a quality test gauge. The will build the hose for you.
Jeff
Old 03-21-2013, 09:57 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
#4ORB...200psi liquid filled gauge from Harbor freight. 18" flexible grease hose from harbor frieght. 1/4nptf x 1/8nptf adaptor from home depot.
Alls needed to test f/p psi. Just made one last week, worked perfect. lso then, you can test oil pressure at hpop resivoir plug too...
Old 03-21-2013, 10:12 AM
Also, Strictly Diesel sells the made in USA liquid filled gauge that comes with their kits separately for $20. It has 1/8" NPT thread.
Old 03-21-2013, 12:19 PM
JMP E350 JMP E350 is offline
JMP E350 is starting off with a positive reputation.
can someone post a pic of how to test fuel pressure ?
where is the fitting you test from or do you have to make the fitting yourself ?
the fuel filter bowl is pressurized at 70 psi ??? No wonder if i don't get the lid on super tight it leaks ...
Also where is the fitting you test high pressure oil ??
Im guessing these are not easily accessible!
Old 03-21-2013, 01:29 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
There are two outlets on the back side of the fuel bowl and they both have caps identical to the one on top of the HPOP reservoir. The one on the passenger side is pressure after the fuel filter, and the one on the driver side is before the fuel filter. If you want to see the pressure that your injectors actually experience, use the one on the passenger side. It's low and not easy to spot.
Old 03-22-2013, 04:00 PM
I bought the harbor freight kit. Is the gauge liquid filled? Is there a way to check the gauge for accuracy? I'm trying to convince myself it will read correctly.
Fuel press tester Iaff113 6.0L Power Stroke Diesel 10 11-01-2014 04:54 PM
Fuel Pressure tester TruckingBill 6.0L Power Stroke Diesel 8 09-03-2014 08:01 AM
Injector tester from India on Ebay irhunter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 01-30-2014 08:49 PM
Fuel Pump Pressure test tmcalavy 1967 - 1972 F-100 & Larger F-Series Trucks 2 01-04-2012 06:16 PM
DIY Diesel tools iam me Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 08-21-2009 04:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
