White/Blue Smoke Until Warm
I have a 1990 F-250 4X4 with around 300k miles on it. The glow plugs (Beru ZD-9s), GP controller, return caps, CDR, return hoses, return cap o-rings (vitron) and injectors are all new. The truck starts fine, and kicks down from high speed as it should when it starts to warm up (5-7 minutes). The tach sensor is new and the speedometer works properly. When I start the truck it smokes a good size cloud of white smoke and as it runs for the first few seconds it continues to smoke noticeably. After about 15-20 seconds it just smokes a little and after 10-15 minutes the smoke goes away. It seems to me that my fuel injection pump may be suffering from excessive clearance due to wear and tear and as the pump heats up the clearances tighten up and the pump performs better. Does this sound right?
The truck seems a little sluggish, but not terrible. It's had new Fleet Carge antifreeze in it for a year and there isn't any loss of coolant and no sign of pressurization of the cooling systen due to cavitation damage.
I'd appreciate any thoughts on what may cause the whit/blue smoke when cold.
Thanks,
Fred
P.S. The injectors were new (Delphis) and not rebuilt, but they weren't pop tested nor patterned.
Thanks,
Fred
jmuenchow
13
10-13-2015 01:58 PM
blackstinky
12-11-2003 10:23 PM
