255deh cam install
255deh cam install
I've read many threads on cam lift and lifter replcement. I'm going to be installing a 255deh cam with new lifters on a new remanufactured 400 stock motor. Most everyone says that as long as I stay below .500 lift, stock valve springs will work? My valves don't have the rotating tops(i forget what there called). What do you think? will I be alright with no spring replcement? .465/.495
It's fine, that's what was in my truck prior to me tearing it down. I also ran a 268H in my old '78 400 with stock springs for years.
Make sure you break in that cam right, run a zinc additive and the proper oil. I recommend Valvoline VR-1 and parts store should carry it.
I bought some oil additive & I'm running( just changed) Shell Rotella-t 15-40. Do you think thoses two combined will be suffcient for proper break -in?
COMP Cams Engine Break-In Oil Additive 159 - SummitRacing.com
15W40 is really thick though, why so thick?
i got 12 oz. bottle of comp cam oil add #159 COMP Cams Engine Break-In Oil Additive 159 - SummitRacing.com
My dad got me that oil and said here. 15-40 is all wally world stocks.
What grade should I get?
Those pics of the timing chain are one in the same. different angle
As for the oil to use my first knee jerk reaction is simply cause in FTE the "which oil should I use" debate is even worse then the manifold or ported vacuum advance debate.
That said my recomendation would be to work your way down in viscosity and up in synthetic until you get to a 0W30 true synthetic. That said for now with the new cam and the engine having 15W40 in it previously. Using the Rotalla T6 5W40 synthetic is a really good choice.
Get some Hyperlube to use as an assembly oil on the cam bearings, rockers,and timing chain.
The cam will come with break in lube that goes on the cam lobes and base of the lifters.
And get 1 or 2 quarts of Mobil 1 0W20 synthetic or if you can't find that 0W30 to soak the lifters in before installing them.
But if you got some crazy ideas that maybe then engine should last more then 100K, not tear itself apart, not spend your fuel pumping around thick oil, and not wait and count the seconds while it rattles and wears out on cold start ups then maybe just maybe a more appropiate oil is a good idea.
Not that thick, can't believe you said that, your funny
Yeah your right, but it's good bang for the buck. If ya think ya need more you can toss in an additive.
Just for curiosity sake what do you think my torque numbers will be after my 255deh cam install with peformer 400 intake,holley 650 vac sec.?
stock 400 block & heads
straight up timing
stock exhaust manifolds, single 2" Y pipe with cherry bomb muff., no tail pipe
auto,33" tires , 4.10's
Maybe around 400ft.lbs at 2500 rpms?????????????
straight up timing
