Air Raid - 2005 6.o Filter - Ford Truck Enthusiasts Forums
Old 03-20-2013, 02:06 PM
adbscu's Avatar
adbscu adbscu is offline
adbscu is starting off with a positive reputation.
Hi,
I have a 05 with an Air Raid filter (got the truck used with it in 08): should I order a new filter (http://www.airaid.com/kit_replacement.aspx)? or just cleaned (did it already a few times..now it's really dirty).
If i go the replacement route (part number 400-131-1) should i go with the SynthaFlow or Syntha Max?
The truck is used for towing (on a weekend basis), we do go down some pretty dusty roads at times.
Old 03-23-2013, 07:48 AM
edawgm's Avatar
edawgm edawgm is offline
edawgm is starting off with a positive reputation.
I would go and find a stock filter.
http://www.ford-trucks.com/forums/10...ror-story.html
Old 04-02-2013, 12:58 AM
caveman's Avatar
caveman caveman is offline
caveman is starting off with a positive reputation.
If you clean it good with the cleaner kit and re oil it should be good. I had mine new in 05 and ran it for 6 years and it was great. I clean it often and was always on dusty Forrest service roads I disagree with the keep it stock fan boys. Each to their own though.
Old 07-08-2013, 05:31 AM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
The stock Donaldson unit on the 6.0s can feed a 500 hp motor. It is super good at catching dirt. I would never go to a aftermarket filter on my 6.0.
Old 08-06-2013, 02:39 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Check the blades of your turbo and I believe you would then return to a stock air induction system......
If you are determined to continue using what you have, go with a NEW filter.
Dorman up pipes MPannell 1999 - 2003 7.3L Power Stroke Diesel 18 04-27-2016 07:43 PM
14 f150 5.0 oil in intake Jr_f150 2009 - 2014 F150 1 04-21-2016 02:31 PM
airdog 2 pfk1616 6.0L Power Stroke Diesel 3 08-20-2014 11:38 PM
Aftermarket Intake and Ford Warranty chris8084 6.2L V8 4 03-10-2011 08:47 AM
washing AIR Raid intake on 6.0? adbscu Air Intakes, Air Filters & Ram Air 3 12-20-2009 04:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
