anyone up for a rearend swap? - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 03-19-2013, 10:02 PM
Dtmaster2008's Avatar
Dtmaster2008 Dtmaster2008 is offline
Dtmaster2008 is starting off with a positive reputation.
Well, after a long and very much anticipated moment I finally have my baby back on the road with a fresh 300 and fmx transmission. Running good and all but I encountered a very slight problem...300s were not meant to have 3.00 hi-speed rear ends backing it. Would anyone be up for a possible trade? Im looking for some thing between the ranges of 3.50 to 4.11, just would rather not have a 4.11 as the pulling is great and all but feeding the beast would be slightly more than whats needed as I do drive it daily. If anyones open just let me know as it would be greatly appreciated.
Old 03-20-2013, 01:12 PM
ChiefM's Avatar
ChiefM ChiefM is offline
ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.
I am not doing a swap but replacing mine, found one with the springs for 300 dollars. That should get it road worthy again. The ring and pinion is worn out plus it has a bent axle. Plus my springs have seen much better days.
Old 07-22-2013, 10:01 PM
tfurman6 tfurman6 is offline
tfurman6 is starting off with a positive reputation.
DT, did you ever swap rear ends? I would likely be open to switching mine I think its 3.5 but would need to reconfirm. How did you switch to the 300? From what motor? I've thought about doing that as my 360 is needing rebuilt but not sure if it was too much work all things considered? Let me know.
Quote:
Old 12-17-2013, 11:21 AM
hey sorry for the long wait as ive just gotten back from military training in Columbia SC. I am still up for the swap but its gonna be on hold for a little longer than expected as my first duty station is going to be in Sembach Germany. yes the swap was not the easiest but it was not the hardest either. I used all the original parts from the 360 and if i can remember right the only things we had to change was the motor mounts by drilling in a couple new holes in the frame itself. The fan spacer had to get cut down as it would have hit the radiator if it wasnt. Along with the transmission we cut out a small section in the cab to add a floor shifter that came out of a FOrd pinto as the way it shifted the gears it was ideal for the fmx transmission setup(ie c6 park was all the way in the front, fmx park was all the way in the back) but other than that it was just a semi difficult swap especially with working minimum wage i had to watch what i spent. Any other questions just give me a holler i should get back on after a little while
Old 12-21-2013, 02:25 AM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
My project for my car:
Been saving the money for nearly a year, got it all apart, just need to get home, knock it all back together and get a driveshaft built. Dunno where you are in GA but I've got a few thirds made up, 4.10's 3.25's etc. They are all early 60's cases tho so they'd need to be drilled for a fill.
300 I6 Performance upgrades Sweetness34 1987 - 1996 F150 & Larger F-Series Trucks 10 10-09-2014 10:24 AM
Alternator Wiring Upgrade bcfarmer 6.0L Power Stroke Diesel 5 08-11-2014 11:34 AM
Ring and Pinion Ration in 1950 F2 frankcowan 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-17-2014 10:13 PM
360 to 300 I6 swap Reddman 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-24-2013 02:32 PM
Dana 60: 4:11 or 3:54 gears? C6, crew cab f250 reignman Clutch, Transmission, Differential, Axle & Transfer Case 3 06-29-2004 12:07 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
