1977 F150 4x4 how to replace C Bushings or axle insulators
Old 03-19-2013, 06:01 PM
F100Lock's Avatar
F100Lock
F100Lock is offline
Exclamation 1977 F150 4x4 how to replace C Bushings or axle insulators
I don't know how to change these. Im not sure if I need to drop the springs or if I could jack the front end up from the frame and then undo it. Thanks for the help in advance.
Old 03-19-2013, 06:20 PM
nine inch rear's Avatar
nine inch rear
nine inch rear is offline
Jack up front end, support frame with tall jack stands. Remove jack and put under front diff. You can undo the top coil spring stay brackets. Undo shocks and tie rods/drag link. Lower axle down, unbolt front c bushing bracket on both sides. Pull entire axle forward away from the radius arms so you can access the rear c bushing. Its not hard, just cumbersome. Use polyurethane bushings so you never have to do them again. They come in different caster angles. 3 degrees is the most common replacement types. Dont forget to undo the brake hose
alchemist1
06-12-2010 03:12 PM
helirich
1978 - 1996 Big Bronco
12-29-2007 10:09 PM
one87zuk
09-14-2004 10:27 PM
bluechow
07-04-2002 11:55 AM
tetraruby
03-29-2002 08:17 PM
Quick Reply: 1977 F150 4x4 how to replace C Bushings or axle insulators
