94-97 F250 F350 7.3 Powerstroke Engine and Truck parts parts - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Old 03-19-2013, 02:10 PM
whodathought whodathought is offline
whodathought is starting off with a positive reputation.
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Location (State): TX
Item Condition: Used
Shipping Information: Item can be shipped
Engine: Part suitable for diesel truck
Part fits:: 1987-1996
All prices are OBO, would really like to make someone a great "package deal" rather than shipping all this stuff a part at a time. Feel free to call or text 817-602-5267.
94-97 F350/F250 7.3 Powerstroke and Truck Parts List:
SCT DashScan $30
Gas Pedal Assembly $75
1996 F350 Automatic Engine Computer F6TF-12A650-AYE EEC-V DPC202 W4 $125
3 IPRs $100
IPC $40
Oil temp Sensor $10
Oil pressure sensor $10
Water temp sensor $10
Air intake temp sensor $10
Boost pressure sensor $20
Vacuum sensor, manifold and reservoir $20
Brake Pressure sensor and peddle light switch $10
Starter Relay $10
Glow plug Relay and 3 Glow plugs $30
Fuel Tank Valve and Switch and fuel lift pump piston $10
HPOP (core) with Gasket, Gear, lines, new O-ring kit, and Tank top $100
1 under valve cover injector harness, 8 injector oil “hats” $20
Alternator $40
New out of box water pump $60
Valve cover breather assembly $10
Oil Cooler Assembly has a small O-ring leak but no rust in good shape $75
Bell Housing Spacer $20
Dual Mass Flywheel $75
Headlight Switch $10
Glove box latch and light $10
Under hood light $5
Blinker Switch $25
Engine Lift Rings and misc. brackets $10
Tailgate Handle and latch hardware with link rods $30
Emergency brake pedal assembly $15
Dash AC vent assembly (1) $5
Dome Light Assembly Older model one but nice $10
2 wiper blade arms $10
Rear drum brake hardware spring parts kit $10
Factor Stereo Amplifier F4TF-18B049-AC $30
Windshield Wiper Control VF3TF-17D539-CA $20
Seat belt Chime VF2TB- 10D840-AA $10
ABS Control Module (dually only) F3FT-2C018-BB $20
Anti-Theft Module and 1 key fob remote $10
Old 03-19-2013, 05:14 PM
Bulletproof7.3 Bulletproof7.3 is offline
Bulletproof7.3 is starting off with a positive reputation.
Anti theft module, what year? Interested in wipers, under hood light-do you have the harness for it as well and do you have any seat belts in gray 94-97 F series reg cab?
thanks
Old 03-19-2013, 07:33 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
What's your package price, no flywheel included? Quite a few other little things I wouldn't need, but I don't want to list them all. I really don't need much from the flywheel down. PM me if you want. Interested in the pcm for sure.
Old 03-20-2013, 07:32 AM
truckrider814's Avatar
truckrider814 truckrider814 is offline
truckrider814 is gaining momentum as a positive member of FTE.
Can I assume that blinker switch means the turn signal lever. If so I'd like it buy it.
Old 03-20-2013, 08:03 AM
anti theft is from a 1995 F350, I do not have any wiring harnesses or seat belts
The Blinker switch is the multi swtich from the steering column.
There are two guy in front of you the are considering a package deal price for it all, if they pass i will contact you for purchasing these parts if that ok??
Old 03-20-2013, 08:15 AM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Text sent as instructed...
Old 03-20-2013, 03:36 PM
Whoda- Thats fine let me know what you end up doing.
Old 03-24-2013, 08:27 PM
all part are sold, in a package deal. Thanks for looking!
Old 03-24-2013, 08:29 PM
Thanks for the update, the search continues!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
88 f150 parts 87-91 fordka Ford Truck Parts for Sale 61 01-18-2016 09:12 PM
460 EFI parts markfuga Ford Truck Parts for Sale 38 10-20-2014 09:40 PM
95 f150 parts fordka Ford Truck Parts for Sale 18 06-27-2014 05:54 PM
PSD Part Numbers tjbeggs 1994.5 - 1997 7.3L Power Stroke Diesel 40 02-08-2014 11:10 AM
Buy this truck? Service history included... Sarge559 6.0L Power Stroke Diesel 8 09-16-2013 08:53 AM
