Door Mirrors - Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
Door Mirrors
Old 03-19-2013, 01:09 PM
white-horse white-horse is offline
white-horse is starting off with a positive reputation.
Door Mirrors
As you can see in my picture, I have the large mirrors that are mainly used for trailering and such. I am thinking of swaping to the standard mirror. I already measured and the bolts on each mount line up perfect. It appears I can easily swap them out. Do all agree? Or will I have problems? Other than being left with the two bolt holes on the lower part of the door? (which I will fill in). Thanks.
Old 03-20-2013, 07:45 PM
donjamer's Avatar
donjamer donjamer is offline
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
I would say stay with the ones you have.. Better visibility even if you are not towing..
If you ever do tow anything you will be glad you have them..
Old 04-12-2013, 02:59 PM
I made the conversion. I like the new mirrors much better. They installed perfect. I was nervous at first, as I had to take the door panel off in hopes to find that center bolt attachment for the new mirror...it was there! No drilling. As for the two holes in each door, I plugged with a stainless round top bolt, painted white. You can tell of course, but it doesn't look hideous. i'm happy...
Old 04-12-2013, 03:01 PM
donjamer's Avatar
That sounds like a good thing using the bolt..
Now you have the option of going back if you choose...
Old 04-12-2013, 03:09 PM
Yeah, that's what I thought. Some said I should weld it closed, sand and paint, others said use bondo (yeah right). The bolt worked great, won't rust, plus I coated the threads and washer on the inside with grease. Done.
Old 04-12-2013, 03:12 PM
donjamer's Avatar
That seems to be the best option if you ask me..
Not much effort and should last a long time..
Mirror swap question 92-96 mirrors TylerJ150 1973 - 1979 F-100 & Larger F-Series Trucks 15 10-16-2013 05:06 PM
Exterior mirror swap str8sixman 1987 - 1996 F150 & Larger F-Series Trucks 5 06-22-2012 10:00 PM
mirror bolt holes FourWheel 1987 - 1996 F150 & Larger F-Series Trucks 2 02-28-2008 07:46 PM
MIRRORS - How to mount them? Hellbore 1973 - 1979 F-100 & Larger F-Series Trucks 26 06-25-2006 02:35 PM
Replacement Mirrors fjszuch Explorer, Sport Trac, Mountaineer & Aviator 3 08-09-2003 04:27 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
