Air Filter/Intake Unit - Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
Old 03-19-2013, 12:56 PM
white-horse white-horse is offline
white-horse is starting off with a positive reputation.
On my 97 f-350 7.3L, is the factory stock air intake system fine for general use? Or, should I invest in a high performance aftermarket? Also, I missed out on the recall they had some years back on the filter houseing cover, something with the screw down bolts or something, anyway, that recall has ended,,,where can I get the "recall" parts now??? Thanks.
Old 03-20-2013, 07:43 PM
donjamer's Avatar
donjamer donjamer is online now
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
The factory stock intake is better than the aftermarket ones.. There are many threads on the subject.. It doesn't have any benefits to replace it..
As far as the recall, did you check out the dealer to see if you are not eligible??
They should be able to get the parts unless they are discontinued..
Also check out the TSB and Recalls for your vehicle at the top menu under Tech Tools
Old 03-21-2013, 10:19 AM
Ok, thanks! I'll keep the factory air filter intake unit, and I'll look at that recall. That recall has expired, can I still get the parts? I guess I have to check with the dealer.
Dropped off for a Recall..... Coskid 2004 - 2008 F150 18 08-12-2011 04:12 PM
290k+ NO PLAY, BUT EDGEGES ARE ROUGH 561DAN 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-13-2011 07:09 PM
Recall question 2004 Excursion HowieE 2004 - 2008 F150 3 04-26-2011 08:04 PM
Recall question Okcdiscgolfer 1999 to 2016 Super Duty 4 05-10-2007 09:06 PM
"Dusted" 1997 7.3L Diesel mhague 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-28-2003 09:14 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
