Banks Torque Tube headers V-10 install w/pics
#61
Great write up. I read this entire thread 3x and each time I get a little more brave and think of trying to tackle this project on my own also. I hope that feeling passes soon.
Which torque tubes are for the Excursions?
This is from Banks site;
Application---------------------------------------Year Range----------- Part #
TorqueTube system----------------------------------1999-04------------49133
Ford 6.8L Trk, W/egr Late Cat
Emissions compliant: CARB E.O. D-161-76
TorqueTube system----------------------------------1999-04------------49136
Ford 6.8L Trk, W/egr Erly Cat
TorqueTube system----------------------------------1999-04------------49138
Ford 6.8L Trk No-Egr, Late Cat
Does your EX have an EGR valve? Mine did not so I bought the #49138. If you do have an EGR it will be on the driver's side exhaust manifold, if not the manifold will just have the solid flat round boss where the valve would have been.
This is my non-EGR manifold.
#62
As an FYI... I did my drivers side and only broke 1 stud. My biggest issue was removing the studs holding the manifold to the y pipe. I have the part number somewhere if anyone needs it. I had to cut mine, there was no head left on the nut.
Sidenote... I changed the studs and gasket and kept everything else stock for now.
#65
#66
Auto anything doesn't list the torque tubes on their site. I have not contacted them I just checked online.
#67
#68
I fired up my little 110V MIG and dialed up the heat and slowed down the wire feed and had at it. Bingo! First try got good penetration, and here is my homemade "bolt".
#69
Out of curiosity, since I'm going to be tacking a similar project myself, what spec of mig wire did you use? I've read that the stock studs are stainless (not sure what type of stainless though). Did you use just mild carbon steel wire (ER70S-2 or ER70S-6) or did you use some sort of stainless wire?
Just plain old ER70S-2 (pretty sure thats it), same stuff thats in the machine 99% of the time for general fixxing/fabbing/playing in the garage. It worked well and the stud that was broken off almost flush with the head surface took the weld very well and spun right out, the other stud was too far inside the head and my little 110v machine couldn't get the weld hot enough in the deeper hole.
Good luck with your install, and stud extraction, it can be a pain but when it's done you will be smiling!
#70
To add, I used Lincoln .035 Flux Core wire when I did mine. One of the studs was 2-3 threads below the head, and got it welded up and turned out. But I did drill a hole in it first, than welded the hole shut, and continued to add weld tell I could weld a nut on. Than some taps with a hammer, some penetrating oil, and tighten, than loosen, wiggle back and forth n slowly turning it came out.
#71
I started mine tonight. We got the inner fenders out and the shocks. Everything is sprayed with penetrating oil. I also cut the bolts off to the Y pipe. We're trying to figure out how to reach the O2 plug on the right side. We have 8 broken studs, 2 are flush with or below the head(maybe 3).
#74
Good luck!
