Diagnostic Connector Plug
I have a 94 F250 7.3 diesel. I'm looking to get more power when towing my Jet Boat. I got a Evolution Programmer from Edge. I cant seem to find the Diagnostic Connector plug in, I have looked under the dash on the drivers side,under the dash by the power port, and even under the glove box. I have checked under the hood too, I NEED HELP in a bad way.
PS Pictures would be helpful
It's normally under the hood near the firewall on the driver's side by the fender (where the ignition module would be if it were a gas engine).
Pictures here:
Fuel Injection Technical Library » How To Run a Self-Test
Be aware this is an OBD 1 computer, not sure if your programmer thing is gonna be able to do anything with it.
Pictures here:
1994 was a transition year from the older IDI diesel engine to the DI (Powerstroke). Depending on which one is in your truck will determine if you can use that programmer. I am not a diesel expert, but the folks in these Forums are:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
DriveFords4Life
11-02-2007 08:53 PM
