1997 F350 replacement tailgate - which years? - Ford Truck Enthusiasts Forums
Old 03-18-2013, 09:18 PM
bithead08's Avatar
bithead08 bithead08 is offline
bithead08 is starting off with a positive reputation.
Searched the forums and google but didn't find a definitive answer. I bet you experts out there know this one off the top of your head:
What year tailgates will work on the 1997 F350?
Old 03-18-2013, 09:19 PM
bithead08's Avatar
There's one on CL but doesn't list the year. I emailed the poster.
Ford Tail Gate
Old 03-18-2013, 09:21 PM
lud04X lud04X is offline
lud04X is starting off with a positive reputation.
I would bet 1992-1997 F250 and F350 tailgates would all work. Not sure about the F150 gates between 1992-1996.
Old 03-18-2013, 09:29 PM
bithead08's Avatar
Quote:
Thanks for the reply, but "I bet it would work" and "Not sure" sounds to me like you don't know what the heck you're talking about. Just sayin.
Anybody out there know for sure?
Old 03-18-2013, 10:10 PM
bearhugger's Avatar
bearhugger bearhugger is offline
bearhugger is starting off with a positive reputation.
I know for sure that a 92 will fit a 96 because i just bought one.
Old 03-18-2013, 10:51 PM
bithead08's Avatar
Update: the tailgate on CL is from a 2002 F350 super duty.
Will that fit on my 1997 F350 without any modification, and will it "look right"?
Old 03-18-2013, 10:55 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
'87 to '96 F150s and '87-'97 F250 and F350 tailgates will fit. If you want a smooth tailgate, don't get one with the wide aluminum panel across the back. When you take that off, there are several holes in the tailgate.
Old 03-18-2013, 11:06 PM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule has a good reputation on FTE.BlueMule has a good reputation on FTE.
You can go back as far as the 7th generation trucks (80-86) and the tailgates will interchange with the 87-91 & 92-97 body style.
incorrect.
86 and older tailgates used a different latch than the bolt style on the 87 and newer gates.
87 to 97 F-150, F-250 and F-350
Old 03-18-2013, 11:08 PM
bithead08's Avatar
Thanks, Bill and Rodney!
Old 03-19-2013, 08:59 AM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
For a slip on and use tailgate go with the 87-97 years, as the 80-86 latches are different. The latches for the later years may fit on the 80-86, I've never tried to see.
Old 03-19-2013, 05:56 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Quote:
incorrect.
87 to 97 F-150, F-250 and F-350 is what you need
Old 03-19-2013, 06:09 PM
bithead08's Avatar
Quote:
I appreciate a good solid definitive answer like that.
This also jibes with the other replies above.
I had read about various latch/cable/hinge differences but it was still very murky.
Thanks!
Old 03-20-2013, 03:57 AM
i ain't rite
the 87 and newer uses cables.
like was mentioned, look for a solid panel gate. the XLT lariat gate has an aluminum panel on the back. the plastic center falls out and if you try to eliminate it you end up with 4-5 holes in the tailgate.
F-150 Tailgate bmarv33 2004 - 2008 F150 0 03-03-2015 04:34 PM
F 150 (1999) Tailgate compatability?? roadtripdaddy 1997 - 2003 F150 1 12-07-2014 05:09 PM
Tailgate 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 3 06-25-2013 07:04 PM
Tailgate 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 12 05-09-2013 06:45 PM
tailgate compatibility ssuazo 1987 - 1996 F150 & Larger F-Series Trucks 4 04-10-2013 01:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
