Tstat, water pump..fan clutch?
on
i really like my e-fan swap.it's been working great for a long time now.lot's of bonuses to running 'em.
details here;
https://www.ford-trucks.com/forums/1...ar-diesel.html
details here;
If i decide to go for a new fan clutch, anyone had good experiences with certain brands?
ALSO, great to find that my water pump did not come with a gasket, good to find that before i drain my truck of coolant and have it torn apart and discover i have no gasket to put the pump on with -.-
when i was planning to replace my non-functional fan clutch, i bought every brand i could find without going to the dealer, and nothing i tried was any better than my old one. they should lock up when they get hot enough, thats the whole point, but none of them ever did.
i've heard rumor that the ones straight from ford actually work like they're supposed to
on a related note, removing the fan clutch from the water pump isn't always the easiest thing, as most parts stores can't order the wrench for it. so after looking all over town, i bought myself a vise-grip style chain wrench from harbor freight, its a bit tricky to wrap the chain around the wrench flats of the fan clutch, but once its on there, use a hammer to turn the wrench, while the belts remain in place to hold the water pump still for you. remember that it has left-handed threads, so removing the fan clutch will have you beating your wrench toward the drivers side of the truck
f250hdxlt, your post suggests that screwing up the order of water pump bolts will frig up the IP, that must be an error... but that is a good plan for how to keep your bolts in order
on
Yeah f250 i've heard of the horrors. with the new water pump came 2 new bolts not sure for which holes. probably the top 2 that everyone speaks about, will have to see how long the old ones are, not sure if i need to use the new ones or not.
I suppose i'll head to the ford dealer to buy one. ugh, probably really expensive.
and luckily my father has BOTH wrenches for the fan clutch, probably 20 years old those things haha
I guess while im there i'll take it to get it rotted out
Just seems really really hot under the hood after running
With how easy it is to install a real gauge, you should really install one. No more guessing games afterwards.
I got a Sunpro temp gauge from Autozone, something like 20 bucks?
Run the probe to the Temp light sender at the front of the drivers side head, (using that sensor, allows for your dash gauge to keep working, as well as having a real gauge reading), run that through the firewall, and hook up powerground to the gauge for the light bulb to work, and that's it.
